Old 01-06-2019, 11:47 AM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Originally Posted by Mr Anonymous View Post
When looking at 20-24ft trailers, play close attention to GVW "rating". Five lug wheels almost always means a 3500lb axle, which means two axles = a 7,000 gvw trailer. Six lug wheels are 5,000lb axles and a 10,000 gvw. Most all of the cheaper 24 ft trailers have the 3500# axles. The unloaded weight of the trailer plus a car can have you at 7,000lbs very easily. Add in a golf cart, toolboxes, etc, and there you go. If you buy a 7,000lb GVW trailer, plan on keeping spare hub/drum assemblies and wheel bearings with you.
You'd be surprised at how many private individuals selling trailers have no idea what the GVW rating of their trailer is.
When I went shopping for a 24ft enclosed, I looked at probably two dozen before I found the one I have. 10,000gvw but its pretty beat. Minus one very annoying and hard to diagnose intermittent electrical short, its been a good unit.
6 lug are 5500 lb rated...
  #42
Old 01-06-2019, 11:58 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is online now
https://thetrailerpartsoutlet.com/5k...UaAqCeEALw_wcB
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
  #43
Old 01-06-2019, 12:42 PM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
I agree 6 lug is the only way to go
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
  #44
Old 01-08-2019, 01:25 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Thanks guys - this has been very helpful. Mostly I was interested in the more basic - lower end trailers. Currently I am considering a new 2019 H&H '24 with 5,000 axles - $7,150. - Any thoughts?
Thanks Again, Craig
  #45
Old 01-08-2019, 03:20 PM
sdbob sdbob is offline
Waiting for mine at SAY Trailers. Any day.
  #46
Old 01-08-2019, 08:20 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I borrowed a 20 ft enclosed for a 73 Ventura and it was tough getting it tied down in the front.
  #47
Old 01-08-2019, 08:38 PM
Strange ,left work, went to pt,message from SAY, trailer is in. 26ft Tail Wind. Finished inside,etrac in floor.To dark to take pics. Probably ,very busy right now,pick up next week.
  #48
Old 01-08-2019, 11:37 PM
Mike Davis's Avatar
I went from a 24ft to a 28ft and still need more room. I don't think you can ever have "enough" room in a trailer.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #49
Old 01-09-2019, 11:55 AM
Any trailer... here are some things to consider.
Winch cable through deck under a roller and back up to vehicle tie point. Cable also goes over roller on deck. Add some frame stops(preferably adjustable like a jackstand center coming through deck) and front ain't going anywhere . Add adjustable stops in rear and ratchet straps to lock it down on stops, vehicle secured.
Fenders too high for door clearance is easy to resolve with pieces of 2×12 on deck.
Steel wool dipped in oil (wrung out to not drip) and stuffed in holes is very effective for pest control. They won't eat it or nest in it(even daubers). You can use light coat of spray paint vs oil in areas that only see dampness. (or just leave it as is and change out steel wool as needed)
