Old 01-12-2019, 05:58 PM
BOB VIDAN BOB VIDAN is offline
Default Hate This CRS Stuff - Another What Is It?
This little guy goes where/year? ID is 3/4"
Practicing social distancing for 65+ years
Old 01-13-2019, 10:41 AM
olde-goat olde-goat is offline
Can't tell exactly from your picture, but without going under my car to look (getting harder to crawl under my car) I believe it is the support bracket for either the speedo cable or emergency brake cable
should have added '65
Old 01-13-2019, 11:56 AM
Tough to tell. 3/4" I.D. is pretty big for any line or cable. The only thing I that comes close that I can think of would be heater hose but I am sure its not for that.
Old 01-14-2019, 02:27 PM
Slider Slider is offline
Is it the metal clip that holds the fuel line near the alternator bracket?
Old 01-15-2019, 01:44 AM
Nope, too big for fuel line.
Old 01-15-2019, 08:30 AM
The Champ's Avatar
3/4" is heater hose size I think, but that's not the right one for a '64 GTO if that's what it is.
Old 01-15-2019, 07:20 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Actually, 3/8" fuel hose is a little smaller than 3/4" OD, so that would fit.
3/4" heater hose (and even 5/8") is way bigger than 3/4" OD. Hose is measured by ID.
Since 3/8" fuel/vacuum hose would fit, how about brake booster hose bracket? Interesting thing about that bracket is the small #10 or so screw hole. That tells me it's not mounted on an engine. Could also support a wiring harness (on the back of the cluster maybe).
Heinrich
Old 01-29-2019, 03:55 AM
Bob Moore's Avatar
Bob Moore Bob Moore is offline
Looks like speedo cable bracket bolts on floor pan at the throttle pedal bolts
If you are looking for a mobile living room in these pages, forget it
Old 02-03-2019, 01:31 PM
bill ryder's Avatar
bill ryder bill ryder is offline
You still have that brkt. I may have a use for it!!!!!!!!!
"Bill"!
MEeeeeeeeeeeeeeeeeee
Old 02-03-2019, 03:00 PM
I have it, if I can find it but it won't work for a snow shovel.
Old 02-03-2019, 03:40 PM
bill ryder's Avatar
Don't let CRS get you down, my great friend!!!! I know you can locate it. BUT if you can't just ask Cheryl. She will know where you put it!
MEeeeeeeee
