LookMy bottom crank pulley is half a groove too shallow. It needs to come out about a half groove. When I pulled the engine I let timing cover and pulleys go with it except for the alternator braket. So I'm wondering if I don't need a different pulley. Any help would be appreciated.
These photos are of the crank pulley I have now. Last edited by hobbygto65; 01-20-2019 at 07:57 PM. |
What timing cover and pulleys are you running now,what did they come off of?Tom
The alternator and bracket is original, so I know that's right. I have same one on my Cat. Timing change cover and balancer are 1966. The alternator and water pump pulleys line up.
the 63s V8 tempest came with 4 bolt timing covers early and 8 bolt later.Do you remember which you had?You will need the 63 lower pulley .Dave Johnson might be able to help with it.He is on this board.Tom
It had the 4 bolt water pump cover but it has 66 eight bolt cover now.
I think I'm going to have a 3/8" spacer made to go behind the pulley, that should line it up.
I have a zillion pulleys including 63's. Do you know the P/N of what you need?
Don't know the part number. Got a 1/4 inch spacer and now it lines up perfectly, so I'm good. Thanks.
