Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
How do you guys think a 114LSA Old Faithful cam would work in a twin turbo 468 With Edelbrock round ports and Fuel Injection using a Victor EFI /Elbow and 102mm LS Throttle Body?
(Old Faithful specs: 236/245 dur @ .050" lift .578"/.582" lift 114 LSA)
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
I would try it but that cam would probably be done before 5500 rpm.
Even in a turbocharged application? It pulls hard to 5900 in my wifes car N/A with the 112 LSA
![]() Quote:
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
I have a very similar cam 579 lift little more duration, single turbo, rev limiter set at 6500 have bounced it off of that many times. I try and shift @ 6000 but spinning sometimes delays my shift while getting the car under control.
So, would you say it's doable? And what kind of power are you making with it?
My 462 pulls hard to over 6000 with a 224/224 114ls at 18 psi. My cam is installed straight up 114 IC.
In a naturally aspirated sense maybe, but in a turbo application it would be great with the rising torque curve of boost. More boost the more it pushes it.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
The size of the cam is fine. Its the opning and closing points that are critical. What are they??
My Half AN Injun..... |
Some fella commented that a 4/7 swap cam would be good with the LogHeaders and...he may be quite right!
As if no Reversion could occur. The way an H-plane intake provides inhale isolation. Will need to break out the flow charts to see about that. |
Here ya go
The exhaust closes a little late , but its not too bad . Id try it if thats all i had..
Its close to the lift and duration i use .. Should work...
If I had it I would try it, I can only guestimate by my MPH at the end of the 1/4 cause I spin 1st and 2nd, but at 11-12 psi I trap at 145 mph. Car is close to 4000 lbs with me in it. I would say I put down 700-800. I have not turned it up because on the street it is a waste.
I have that cam on my single turbo 468 except it’s on a 112 LSA with the 4/7 swap it pulls hard to 5800 on 12 lbs of boost ...we installed it 4 degrees advance as well ...
![]() Quote:
performance is doing me up a set of 95cc 325cfm Edelbrocks with T washer inserts. She should make good power.
