Old 10-21-2019, 08:36 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
Default aluminum radiators
hi guys, have any of you put a alum radiator in your 2nd gen? im looking for a direct fit so I can use my shroud and mounts. most of the ones I,ve looked at have to us electric fans. the griffen is wayyyy pricey. I can recore my oem rad but its 475.00 minimum. so let me know whats worked for you. thanks, BLUE TA
Old 10-21-2019, 08:59 PM
I would check out Cold Case.
Bill Nye.
Old 10-21-2019, 09:09 PM
Grand73Am Grand73Am is offline
I installed a Cold Case in my 79 TA a couple months ago. I was having some overheating on the highway, 70 mph with a/c on in 90* weather, and the Cold Case cured it with no other changes. Great quality, polished, and fits like original. And reasonably priced. The tanks are thicker than the original radiator, like a 4 core radiator. So the cutouts in the original rubber mounting cushions are not wide enough. So you can either trim out your original cushions, or buy new 4 core radiator cushions. I bought new 4 core cushions. I'm using the original fan shroud and clutch fan, and everything fits perfectly. So, I highly recommend the Cold Case. I got it at Summit, since it was local to me. Good price and free shipping. Here's the listing: https://www.summitracing.com/parts/rad-gpf18a
Steve F.
Old 10-21-2019, 09:18 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
Cold Case works great in my car.
Karl
Old 10-21-2019, 09:44 PM
I put a Griffin in my 70 Formula looong before the Cold Case stuff hit the scene.
We have since experimented with a Cold Case in another car and I highly recommend them. Fit and finish is excellent, fin count is tight, and the core tubes are 1.25". Cools a 571ci Pontiac no problem in the AZ heat. Hard to beat for the price.
Old 10-22-2019, 07:50 AM
BLUE TA's Avatar
hi, thanks for all the info on cold case. looks like they will fit the bill. BLUE TA
Old 10-22-2019, 10:32 AM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Use your stock shroud and clutch fan with the cold case radiator and it will cool great.
Old 10-22-2019, 10:48 AM
track73 track73 is online now
I use the 28” Griffin. My original radiator sprung a leak so I got the Griffin we used on my stock car. That along with the big fan, a shroud and aluminum water pump, caused the temps to go down so far I had to put a 195 thermostat to get the engine over 160 degrees.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 10-22-2019, 01:16 PM
TransAm400 TransAm400 is offline
I recently installed the Frostbite sold by Holley in my 64 catalina. Fits good inside the stock shroud. Using the stock mechanical fan with a new clutch. It would get up to 210+ after extended driving. I haven’t seen it get past 180 after changing the radiator.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 10-22-2019, 01:53 PM
389 389 is offline
Champions have always fit like a glove for me.. 1964 Bonneville and 1969 el Camino SS396..
Old 10-22-2019, 06:50 PM
tooski tooski is offline
I put a Coldcase in my 68. It works marginally better than the 4 row copper/brass I had. It's mounting brackets moved the rad about 3/8 inch closer to the engine. This caused the fan to be fully inside the shroud, which, I have read here, affects cooling. 180 stat, 2600 rpm 60 mph runs at 175-180. Getting on it will still stay at 180. Old rad would climb to 195-200. After a run down the highway sitting in my driveway would climb to 210, same as old rad, where I shut it down. I'm hoping it will get better when I dial in the tune a wee bit better.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 10-22-2019, 07:03 PM
GTO JONES's Avatar
Do you have a spacer behind the fan? It would work better with the tips outside the shroud.
Old 10-22-2019, 09:58 PM
millennium200 millennium200 is offline
Installed a Rodney Red aluminum radiator in my 75 T/A in 2007 and have had great success. Three Hot Rod Power Tours and no overheating problems.
Old 10-22-2019, 10:34 PM
Oem spacer. The plan is to install a shorter spacer. Had to do carb work first.
Frank M.
75 Firebird
