389 build help
Building a 389 going to put a tripower on it. I have bbc rockers for it and plan to port and polish the heads and enlarge the valves. Question is i have 066 camshaft and a 524886 camshaft. Would you run either of these? If which one and what size and length of valve should i use?
Oh and they are 091 heads...how much would you have milled off them. Motor and heads are 1966
BBC rockers are too long for Pontiacs. You need Pontiac rockers. If longer than stock valves are used, SB Ford rockers might work; they are slightly shorter than Pontiac rockers.
The Following User Says Thank You to Geoff For This Useful Post: | ||
Even if i elongate the push rod holes
Yes. The rocker tip/pad will not be centered on the valve tip. If rocker manufacturers could a rocker that fits a few brands of engines, they would...
