Old 12-02-2019, 10:21 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default Anti sway bar bushing source?
1970 T-A: I want to use my original front and rear anti roll bar bushing "Brackets" (With tabs) but cant find the bushings that work in the factory mounting brackets. Ames, FBC etc have aftermarket brackets with bushings that will work but I prefer to use the original brackets. Anyone have a source for just the bushings? Thx.
1970 T/A
Old 12-04-2019, 09:32 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Did you try AC Delco for the fronts? I used them on my '74 with the factory brackets. I don't have an answer for you on rear bushings as I used Energy Suspension Poly bushings that will not work with the factory end brackets.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 12-04-2019, 10:31 PM
dpoltzer's Avatar
I will look for the AC-Delco then. Thanks 3!
1970 T/A
Old 12-05-2019, 01:41 AM
justincampbell's Avatar
justincampbell justincampbell is offline
I am wanting to order new bushings for the rear sway bar on my '73 Formula. Does anybody know if the Energy Suspension kits sold by Ames will work? I know the end pieces aren't exactly the same. I can deal with that. The thing that concerns me is that the bushings they sell appear to be in 1/8" increments and I believe my bar is 9/16". Will the 5/8" bushings "squish" enough when they are tightened to work?
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 12-05-2019, 03:10 PM
Formulabruce's Avatar
Fronts are available from GM as a truck part. I believe NJSteve found this out. The rear bottom drop link bushings are available from energy suspension. Will post pics and links later on today.
Old 12-05-2019, 08:44 PM
Fronts F-41 or Y92 BIG BAR 15 inch tires.
Old 12-05-2019, 08:50 PM
The REAR DROP LINK LOWER Bushings I have been using are Energy suspension. They are poly, but black.
You get the uppers and lowers in the kit. I only use the lowers as the repop drop links have new uppers installed.
You want to use a locking nut and keep these lubed and barely snug. A suspension is NOT a suspension if it cant move.
Name:	Drop links.jpg
Old 12-05-2019, 10:20 PM
dpoltzer's Avatar
Thanks again Formulabruce!!
1970 T/A
Old 12-06-2019, 12:13 AM
Thanks man!
Easyrider
Old 12-06-2019, 12:19 AM
As I recall I have done some bench grinding on the bushings as the location "dent" in the subframe isnt as big as the mound on the underside of these rubbers. Also make have to grind a deeper grove in the middle, a rounded out one, to make it settle down to the frame. Its not a perfect fit, but will work well.
Old 12-06-2019, 09:58 PM
dpoltzer's Avatar
Looks like NAPA carries the bushings for $20. I will head there Saturday. Thanks again FB.
1970 T/A
