Old 01-07-2020, 07:43 AM
79Poncho's Avatar
79Poncho 79Poncho is offline
Default Tripower on a 455 in a 2nd Gen TA
Has it ever been done? If so, what modifications need to be made?
I ask because this has always been a childhood dream of mine to build one for my 2nd gen. I can image the shaker hood scoop air cleaner(s) will need to be super low profile and completely custom, and I'd need any early valley pan to clear the early intake. Is there a water neck conversion that I can use?
Just wondering if anyone else has considered and been crazy enough to go through with it.
Just imagine it, shaker trips!
Thanks,
79Poncho
1979 Pontiac Trans Am
'75 Olds 350, Muncie M21, 3.23 Posi
The Following User Says Thank You to 79Poncho For This Useful Post:
Old 01-07-2020, 08:15 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Well that would definitely have many doing a double take. Never seen that done.
The Shaker is obviously a barrier to make functional. It would be a real challenge to fabricate a pan and adapt it all. I’m a picky guy so to me something like this needs to look good.
Bonding the shaker to the hood is the easy way I’m thinking. I say do it if its a dream, anything is possible.
Old 01-07-2020, 09:30 AM
slowbird's Avatar
slowbird slowbird is offline
We've done it in a 75 Firebird with a flat hood. So it'll fit but like above post no idea how you'd shaker
Old 01-07-2020, 09:52 AM
1965gp 1965gp is offline
I would start with a full size tri power air cleaner and start cutting
Old 01-07-2020, 10:36 AM
steve25 steve25 is online now
You'ed be doing it for looks only, because a Q Jet set up re-jetted with a open shaker will far out power a trip set up with a closed shaker
Old 01-07-2020, 11:01 AM
slowbird's Avatar
You'ed be doing it for looks only, because a Q Jet set up re-meted with a open shaker will far out power a trip set up with a closed shaker
Do you have actual data to back that statement up? Not sure i believe that
Old 01-07-2020, 11:27 AM
Mr Anonymous's Avatar
Take off the big shaker and use three smaller ones!! That'd be hilarious
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 01-07-2020, 11:29 AM
Remote filter with cold air intake. Then duct work to a simple air box for the carbs. Brackets on top of the air box to clamp the shaker on. Double snorkel to the air box would be even better.
Clay
Old 01-07-2020, 11:41 AM
When I did such on my 77TA just in regards to swapping from a closed shaker to a open one along with swapping over a rejetted Q jet on the same day at the track made for a .5 change in ET .
The swap over was done on a test & tune day and the car made the second run within 45 minutes of the swap and the day's weather factors had not changed but for a 2 degree increase in air temp.
Old 01-07-2020, 12:19 PM
77 TRASHCAN's Avatar
I've thought about such a swap, would be sooo cool!!!
My thoughts are of using a 66 with the 3 big carbs, finging a full size car tripower air cleaner, and going from there. The biggest obstacle, as mentioned above, is getting everything lowered over the carbs to make the shaker work. My thoughts were of leaving the 3 individual air celaners on the carbs...maybe...not sure if that would be best way or not...I am not sure how one large round filter could be done...
Someone would need sheet metal working skills to do this, and make it look nice. Would be the coolest TA, to me...
Shut it off
Shut it off
Old 01-07-2020, 12:29 PM
slowbird's Avatar
From our test (done on multiple cars and engines) the tri-power has been worth a tenth vs q-jet and factory intake. So from your testing and our testing the tri-power would be roughly .05 quicker still, potentially anyway.
Old 01-07-2020, 01:13 PM
Potential maybe yes, but most cars that I have seen that run a tripower on modified motor are way out of wack interms of there jetting needs and are atleast a full tenth off from how they could perform when jetted right.
There's no doubt that it's far easier just effort wise to get the secondary jetting on a Q jet right, or atleast in the ball park then dealing with the two outside Carbs on a trip set up.
Old 01-07-2020, 03:51 PM
ta man ta man is offline
Do a bit of research on airpans. All you would need is a flat airpan with three carb rings.And then figure out a mount for the shaker to sit on the pan.
Old 01-08-2020, 12:20 PM
Old Goat Racer's Avatar
Contact this guy. He's a tri-power guru. And I believe his son has tri-power on his TA ?
Jon Havens. jfhavens@sbcglobal.net
He's in St. Louis
Everybody knows somthin.
Nobody knows everything !
Old 01-08-2020, 01:32 PM
I would imagine that it would be best done as on the average race car with the shaker staying attached to the hood with a plate attached to that the same size as what's needed for the Carb pan plate and then good ole foam to seal it up with some verticle reinforcement stands to keep the foam from blowing out due to ram pressure.
Old 01-08-2020, 04:19 PM
242177P's Avatar
242177P 242177P is offline
I'm just going to leave this here... yeah, it's Photoshop, but it's also fiberglass.
Should allow room for taller filters too. If finished with an eye for detail, like an
OE looking seal to the hood and how the two halves are mated, it could cause
a lot of confusion. It'd probably decapitate hood birds.
Name:	shaker 4534535.jpg
Old 01-08-2020, 10:30 PM
Dragncar Dragncar is offline
I have a 66 Tri Power with the 3 big carbs I might put back up for sale. Carbs need completely gone through but the I.D. Tags are still on them. I hear they are worth more than the carbs or close to it.
Not sure what the intake, carbs and tags go for these days, have to research it.
Old 01-08-2020, 10:49 PM
brut4s's Avatar
brut4s brut4s is offline
I'd ask in the Tri power section
Old 01-09-2020, 03:15 PM
Doug Doug is offline
Smile shaker? NAAAAAAAAAA
Thanks,
79Poncho
Seen at a cruise-in show at Taylorsville NC a few years ago.
Name:	057 (1000x750) (600x450).jpg
