Just found a 62' Pontiac Tempest parts car with the 4 cylinder engine and a 4bbl intake. It's a 2 door post car Are the intakes hard to find? Any value to the engine? It had a 77 Y code if I was reading it right. I went ahead and bought the 4 bbl air cleaner and base. Not much good body wise. Surprisingly good bumpers, fair grill, all the under hood stuff is still there except the carb
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs Last edited by Gary H; 01-14-2020 at 02:43 PM. |
Those are the good heavy castings that can handle some big power. Worth? Not a hole bunch. The last three 4bbl intakes I sold went for $100. They always seem to be a quick and easy sell.
DragStarLeMans |
Please describe or picture the front bumper.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
Both the front and rear bumpers are dent free and the chrome actually looks pretty good. I THINK they would clean up and could be used on a driver
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
When you say they are good heavy castings, are you referring to the block or heads, or both? I didn't know the blocks were different from the 1 bbl one.
4-bbl engine with that code had 10.25 to 1 compression flat top pistons, a hotter camshaft, double springs on the valves, and a 2.5 inch exhaust. Everything on and in that engine is desirable. Keep the exhaust heat riser assembly from the exhaust along with the intake manifold. They should go together.
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
Referring to the blocks. 61-62 blocks are flat across area where head mounts to the block on front side. There is also a transfer lug on left side of the block. 61-62s are nearly 3/8" thick, some late 62 and 63s are much thinner in the same area. I believe the early block also have a higher nickel content? The heads are just run of the mill 389 stuff.
DragStarLeMans |
Does the 62 Have Factory Power Steering?
Is the whole car for sale? Would be interested in buying the car, Need a 4 BBL Cam and Trans axle parts. Let me know if the car is available Please
I don't need a show quality front bumper, but would like one that's pretty nice without re-chroming. Could you post a picture?
Ok, guys. I'll be outta town for a couple of days and get some pictured when I get back.
Sent you a PM
How about the rear bumper picture? I have a serious interest in buying the bumper.
I'm going to try and get back over there the first of next week. I'll PM you.
Thanks.
This car is going to be crushed in a couple of weeks. The only major things left on it are the engine, minus the 4 bbl intake, and the transaxle. If anyone is interested in any parts off it let me know and I'll see if I can get them before it's gone.
Looking to see if this has power steering. If so, would be interested in the power steering pump / bracket / pulley assy.
Thx, Kyle |
No, no power steering
Hello,
Are you able to see the cylinder head casting number? If so, take quick photo of it and attach here. Thanks, Kyle |
It's hard to see if the picture but it's the standard V8 head for 62' that ends in 177
