I am trying to find a Pontiac specific spacer to put a new converter in our transmission Does anyone make one or does it have to be a custom piece?
Th400 trans BOP case Also if anyone has one laying around they want to sell let me know! |
I don't understand your question. Are you trying to put spacers between the convertor and the flexplate?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
should’ve been more exact, i am looking to put a spacer between the transmission and the engine using the 6 bolts around the outside to push the trans backward
why ?????
we are trying some new converters and one of them is made for a different spacing
every gm and aftermarket converter I have ever used fit with out a spacer you sure it was seated in the tran's fully ??? unless it was a big time lock up style -- those use a spacer
If you buy an aftermarket adapter from chevy pattern to BOP, you'll have a spacer. Jegs sell them for around $50.
https://www.jegs.com/i/JEGS/555/60172/10002/-1 Not sure why you need a spacer, but you can modify it to suit your needs. Okay I see why you need one. Jegs doesn't give a thickness spec so not sure if that works for your application. Good Luck. |
I know it’s a very strange fitment
Unfortunately i can’t say much because it’s not mine to give the information out on but it’s a normal converter |
[QUOTE=Sirrotica;6123015]If you buy an aftermarket adapter from chevy pattern to BOP, you'll have a spacer. Jegs sell them for around $50.
https://www.jegs.com/i/JEGS/555/60172/10002/-1 Not sure why you need a spacer, but you can modify it to suit your needs. Okay I see why you need one. Jegs doesn't give a thickness spec so not sure if that works for your application. Good Luck Thanks I’ll call and see if it’s thick enough |
You basically need a rear engine plate?
How thick does it have to be? ![]()
Already have a mid plate in the car, Basically i am looking for something similar to this but BOP fitment
Just cut it out of a plate of aluminum?
How I did the midplate, just don't use all the extra width? Trace it on a piece of aluminum and cut with jigsaw. Half hour of work. ![]()
I’m trying to be lazy here and buy it! I will do that if i have to i was just hoping not to
Washers
The Following User Says Thank You to Mark G For This Useful Post: | ||
at one time CSR made a carbon fiber tranny shield for a Pontiac application if they still do you might be able to get the steel plate that attached it to the engine.
I tried someone’s converter that was built for a 1/4” mid plate where I had an 1/8” in my car. I just spaced it out with washers. Not the smartest thing to do but it worked for what I wanted to accomplish. Now, when you space the trans back .125” you also need to move
Back your trans x-member or slot it to fit. |
![]() Quote:
Just get a spacer plate laser cut out of steel in any thickness you want, that's how we get our BOP to Chevy trans adapter plates made. I could send you one over but the shipping will be $30-40.
You could buy another midplate and stack it between the other midplate and the transmission.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
So the ears are moved forward on this converter? If it's just the pilot normally they screw on the converter and you can change it out
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
