Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Cast 62 428 HO SR heads
Cast #62, 428 H.O. “Service Replacement” Heads:
I am the 2nd owner of these heads (not junkyard/salvage heads) Original owner had these on his original # matching 428 H.O. (I have the PHS) The story from orig. owner was he had problems with his factory original 1967 heads and dealer replaced with these nearly identical Cast #62 Heads (used on 68-69 428 H.O. Engines). Uniquely, the date casting for these heads are B283 (February 28, 1973) which was nearly 4 years after last standard Cast #62 428 heads were produced. The engine these came off supposedly ran and in all probability these do not have many miles on them (the car sat since the early 1980's), however I cannot personally attest as to whether they will bolt on and run – at least recommend a valve clean up and re-seal. $500. Shipping options up to you, I can box up or you can pick up locally in Chicago area. I could possibly hand deliver part way if you are in the Midwest for a small fee.
67 GTO street car - 428, roller cam, TH400, GV OD, through mufflers Best ET - 11.44. Best MPH - 116 67 GP Convert 428 HO Project Car |
I have #62’s on my ‘65 Goat 389...Excellent heads...
#62 heads
any photos
PS - those are lead deposits on the valves which tells you these have not really run since leaded gas was common at the pump.
Some photos after some moderate cleaning...
