Sprint Throttle Bracket
Wondering if anyone out there has a throttle bracket for a Sprint that they'd like to part with. Thanks in advance.
Are you looking for the part on the carb or intake for a 68-69 cable?
The part that bolts to the intake that clamps the cable in place.
1968 sprint Throttle cable bracket
This is the bracket that is on our 68 Firebird Sprint 3 speed . The car is all original. is this the only one they used or were there 2 different ones - automatic and manual ?
That one is different from the ones I’ve seen in the past. I’ve never seen one that has the lower part on it. Was that an A/C car?
Throttle bracket
It is used for the automatic kick down. Got this picture off the OHC Facebook group. Do you have a picture of one without the kick down . What year are you building ?
Throttle bracket
Forgot to add the pic
The Bracket with the Kickdown mount was used in some 69 Firebird Automatics with the optional TH350 3-speed automatic, very rare part. All other years that used the ST300 2-speed Automatic did not use that Bracket.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
Throttle Bracket
Our all original 68 Firedbird Sprint 3 speed has the bracket and the bell crank that goes with it. Was there a manual bracket and bell crank as well? Put car is a 2 owner numbers matching with all paperwork and maintenance records.
This is the one that I'm looking for.
As far as I know the only throttle differences are 66-69 A-Body all the same, 67 F-Body used totally different throttle linkage as they used a throttle rod not a cable, and then the 68-69 Firebirds, the manual trans cars used the same brackets as the 66-69 A-Bodies, and the automatic cars may have used the one with the kick down cable attachment for the TH-350 trans. I have never owned a 68 OHC-6 F or A Body, so I don't have direct knowledge of what they used.
Hopefully Jeff can come up with some Pictures. And yes that last picture is what I am used to seeing as a throttle cable bracket
I have one for a sprint 69 with auto trans (ST-350) . you can still use it
69 Trans AM RAIII Auto 69 Firebird 350 HO 4spd Black survivor Last edited by maxepr; 04-22-2020 at 06:40 PM. |
FWIW...
Firebird Linkage parts book pages.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:15 AM. |
Thank you!
FWIW; That's Jerry Woodland.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
