Hey guys, my 69 GTO 400 , 11 bolt water pump is beginning to make noise so I think I'm needing a new water pump. Also, I noticed coolant at the valley pan where it meets the timing chain cover. Appears that I might need to replace gaskets all around and a new water pump. My question is do I need any special tools for removing/installing the timing chain cover. I've done water pumps but never the timing cover. Thanks a bunch all and stay safe! - Will
Will |
It is fairly likely that coolant bypass is what's leaking. However, if your water crossover isn't separated from the intake, you'll need to pull either the intake or the timing cover to replace the rubber o ring that seals that passage.
right, I'm thinking it's the timing cover. Any specials tools needed to do this.
Will |
Getting the harmonic balancer off is potentially the only serious challenge.
![]() Quote:
A few things I would do if you have not done it is; Make sure you have a cast impeller Clearance the impeller.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
if the leak is at the timing cover to intake, you dont need to remove the timing cover, taking off the intake will let you replace the rubber O-ring that seals to the timing cover. a leak at that spot is common, might just need to tighten up the bolt.
but if the WP is making noise & you are replacing it anyways, then just pull the intake when you do the pump. research how to clearance the impeller to the plate, use some good ultra black or grey permatex gasket sealer on both gaskets for the WP, just a thin layer spread out with your finger, & i use a thin coat on the O-ring too just to seal any pitting that may be there. also a big thing is to just start the intake bolts & tighten the timing cover to intake bolt to pull the intake forward to seal the O-ring, then tighten the intake bolts. retorque the WP & timing cover bolts after a few heat cycles & it should be leak free. & there are no special tool to pull the timing cover... the balancer is slip fit so should come off & reinstall pretty easy. Last edited by 78w72; 04-30-2020 at 10:56 AM. |
Just curious has the timing chain ever been replaced....how many miles on it?
as long as I have owned this car - 1996 - I have not replace the timing chain and I believe it has 150K original miles
Will |
![]() Quote:
Will |
The Following User Says Thank You to WillV For This Useful Post: | ||
If you do try tightening the long bolt, be CAREFUL. With the intake torqued down, nothing wants to readily move and the bolt is the weakest link!!! just saying
