Old 05-07-2020, 03:39 PM
raphsutton921@gmail.com raphsutton921@gmail.com is offline
Default Drums to dics
Hey guys got a 70 Catalina trying to convert my drums to this what can I do
Old 05-08-2020, 10:38 AM
Mark G Mark G is offline
I would leave it alone nothing wrong with drum brakes. JMO
Old 05-08-2020, 10:54 AM
Scott Stoneburg's Avatar
I would convert the front if they are drum, look at another GM body that came with front disc and use that set up. May require different spindles too
Old 05-11-2020, 05:50 AM
b.hill b.hill is offline
I used Master Power Brakes to convert my 64 Catalina front brakes. Came as a complete kit with the master cylinder. It was a very simple install kit. But beware of the cheap bearings they supply. It cost me a stock spindle. After that I converted the bearings to a good Timken bearing and haven't had an issue since.
Old 05-11-2020, 01:00 PM
CatalinaMike CatalinaMike is offline
Contact Scarebird
Old 05-11-2020, 03:35 PM
Dragncar Dragncar is offline
What kind of brakes are on your ride Mark ? Kicking around a brake upgrade at the moment myself.
Old 05-12-2020, 07:26 AM
Strange on the front 10in drums on the rear .I had disc on the rear but hated the feel of the pedal. I worked at Midas for years as a brake tech I like drum brakes I know I could save weight with disc on the rear but not for me .
Old 05-12-2020, 05:51 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Agree. I felt mine actually stopped better with the 4 drums vs the 4 Wilwoods.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 05-12-2020, 06:48 PM
It will stop better more surface area .drum brakes get a bad rap ..
Old 05-12-2020, 08:37 PM
wrench's Avatar
wrench wrench is offline
The guy that used to be a tech at Midas says use drum brakes on your race car. I would definitely take his advice.
Old 05-13-2020, 12:15 AM
He never said he had a race car .. .But my buddy runs 9.50 with his firebird drums on every corner stop just fine.. Pay attention
Old 05-13-2020, 07:19 AM
AG's Avatar
AG AG is online now
I run 4 drums on my race car and it stops fine. Never felt the need to go to disc.
Old 05-13-2020, 08:06 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Drum brakes suck! They have good bite under light pedal. Try to do hard stops and they are horrible. My car had factory power drums. I switched to B-body 12' discs and tall spindles. Went with manual master cylinder. I left the drums on the rear for now. Brakes feel great and no booster. Plus discs are MUCH easier to work on.
Midas is one of the biggest ripoff houses in the business btw.
Old 05-13-2020, 09:19 AM
If you keep drum brakes give strong consideration to upgrading the brake pads to a higher performance level. When I had drums these are what we used, others here might have suggestions for other similar companies as well.
http://www.musclecarbrakes.com/index.html
Old information here:
Old 05-13-2020, 12:36 PM
I agree Midas is a very crooked I work there 35yrs ago before it was so corrupted
Old 05-15-2020, 12:57 PM
Originally Posted by CatalinaMike View Post
Contact Scarebird
I have contacted them they don’t make it for my 70
Old 05-15-2020, 01:01 PM
I have drums all the way around
Old 05-15-2020, 05:07 PM
Leave it upgrade the shoes enjoy your car.
