Old 06-25-2020, 01:42 PM
grd777 grd777 is offline
Default 1973 firebird core support threaded washer
looking for two of these , does anyone make them or looking for 2 good ones
Name:	IMG_3313 (002).jpg
Old 06-29-2020, 12:48 PM
bump
Old 06-29-2020, 05:42 PM
ladytata's Avatar
ladytata ladytata is offline
Ames sells them
Old 06-30-2020, 02:25 PM
Formulabruce's Avatar
Originally Posted by ladytata View Post
Ames sells them
Really? was on page 237 ( F25) and only see the old camaro bolt and nut and washers?
Also these were made in '75 And up with No indent ( completely flat) because the car header panel located the nose . Thoughts?
Old 07-01-2020, 08:31 AM
ladytata's Avatar
Old 07-01-2020, 08:34 AM
ladytata's Avatar
I just looked, I don’t see them either anymore
Old 07-01-2020, 08:39 AM
ladytata's Avatar
Forgot I got new catalog, they are generic,
Old 07-01-2020, 01:31 PM
Looks like FS763B is the 70-71 style and would work if it has tabs to locate the nut in the bottom subframe hole.
Old 07-01-2020, 08:35 PM
i did buy these they do not have any tabs to keep them in the hole like the original ones
Old 07-01-2020, 11:24 PM
You can weld a washer on the bottom. I think that was mentioned, and the size needed, in the video. It NEEDS to be located so the core can only move side to side. This sets the front to rear distance.
Old 07-02-2020, 12:20 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
I wonder if they're just using the AMK shims?
https://www.amkproducts.com/search-result/?ser=9790393
So long, farewell.
Old 07-02-2020, 03:23 PM
That could be. The original clips on that "shim" is what had the 3 tabs ( on bottom) to index the core support mounting, with the nut on the top.
Like I said in the video, I welded a nut on top and washer on bottom to make it work correctly. The washer needs to be 2.5 diameter.
could weld a washer to the bottom of a 75-77 unit as it is flat and has no "indent" because the header panel sets the distance.
Old 07-02-2020, 03:53 PM
this is what i got from ames
Name:	IMG_3331 (002).jpg
Old 07-02-2020, 05:17 PM
Yeah, thats not going to stay in place in the subframe. .
I may buy some from AMK and weld washers and nuts on them for people.
Old 07-02-2020, 06:39 PM
let me know i will buy some , thanks for all your knowledge
Old 02-09-2021, 08:23 PM
still looking for the 73 ones
Old 02-10-2021, 10:11 AM
ladytata's Avatar
I have these for sale,$50 plus shipping
Old 02-10-2021, 04:33 PM
how much to ship to Woodbridge , ontario canada
L4L 9A6
Old 02-10-2021, 04:56 PM
ladytata's Avatar
I’ll have to get a quote tomorrow
Old 02-10-2021, 06:20 PM
ok thanks
