Small pilot flexplate
I don't know where to post this moderator please put it where it needs to go.
Where can I by a new flexplate for small pilot 2.50in 77 pontiac crank. The one I have is bent or warped? Thanks Greg |
Did you check ROCK AUTO? They usually catalog most aftermarket manufacturers.
I likely have one from a 77GP SJ I took an engine out of. What car is your engine out of? Some had an abbreviated balancer (no outer hub), low rpm intended use. If all else fails that's what I have, no idea on condition. |
I think the Pioneer FRA-117 fits that description.
http://www.autozone.com/drivetrain/f...sion/52076_0_0 http://www.oreillyauto.com/site/c/de...3232&ppt=C0338 http://www.ebay.com/itm/Auto-Trans-F...3D192122512363 https://www.summitracing.com/parts/p...YqMaAms68P8HAQ The ATP Z-144 also has the 2.5" hole. http://www.ebay.com/itm/Auto-Trans-F...38.m2548.l4275 http://shop.advanceautoparts.com/p/a...-144/5610281-P https://www.amazon.com/ATP-Automotiv.../dp/B000C8PCT4 https://www.summitracing.com/parts/a...dsQaAixE8P8HAQ Last edited by ponyakr; 04-24-2017 at 10:27 PM. |
I dug this back out because I am trying run down a slight vibration and noise,
My 400 engine has the 2.50 inch crank and when it comes to flex plate do I need one for internal balance engine or external? And what would happen if you got it wrong? Thanks Greg |
