Old 10-11-2020, 06:12 PM
unruhjonny's Avatar
Default possible '67 Quadrajet
I would appreciate some help from any experts here;
I just aqquired what I immediatly identified as a 1967 Pontiac Quadrajet.
This carburetor appears to have recieved a service replacement fuel bowl at some point;
I am currently soaking it, and after cleaning it, I will get the airhorn number.
This is what I have gleaned from this carburetor to this point:
has large pot style vacuum actuated throttle stop(?) mounted via front airhorn screw and front lh carb bolt
has 1967 style mechanical choke;
secondary choke rod is mia;
has plastic cam;
throttle body date 0047 (jan 4th, 1967);
casting number: 7033616
airhorn has uncovered fuel bowl vent like a '67 Pontiac unit
has slotted secondary butterflys;
has large secondary fuel squirters;
casting number: TBD
probable service replacement fuel bowl stamped (not OE stamping) 7037272 over smaller 7028240;
casting number: 7034814
I would appreciate any insight or input that anyone might offer.
1970 Formula 400
Old 10-19-2020, 03:15 PM
gtojeff1967 gtojeff1967 is offline
fuel bowls were not stamped in 66-67 they had a round trim tag that went in a hole on the side of the carb, parts place lists them for sale if you need them.
Old 10-20-2020, 10:37 AM
unruhjonny's Avatar
this carb has a twice hand stamped service replacement fuel bowl;
I am now thinking the fuel bowl is a Buick SR part.
ID:	551842   Click image for larger version
1970 Formula 400
Old 04-26-2021, 12:23 PM
unruhjonny's Avatar
I'm giving this thread a bump;
I am wondering if anyone dealt with service replacement fuel bowls, and if it's possible for this fuel bowl to be on which was used for Pontiac's.
I haven't seen an NOS unstamped fuel bowl in a VERY long time, and don't know which part numbers correlated with which casting numbers.
I am hoping for some help here.
1970 Formula 400
