I’m using the BOP valve cover spacers and the Pontiac aluminum covers. Harland Sharp rockers. Checked for clearance and it’s good. When engine still cold not to bad. Only when it gets hot there’s some noise. Again it’s nothing horrible or even bad. It’s just I can tell the difference and wondering why? The valley pan is as quite as one would hope. |
Excuse the hand drawing .
When cleaning the block, were the oil galleys cleaned with a rod ran through them? (just boiling them out doesn't clean them) A lot of blocks seem to have a huge sludge type build up in them especially on that side. (end of line basically)
Made a slight correction to your drawing Steve. The oil for the studs in the pre-64 heads is metered by the holes in the #4 (left head) and #2 (right head) cam journals.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. Last edited by Bill Hanlon; 11-08-2020 at 10:54 AM. |
lifter oiling
Have you tried moving the noisy lifters to the front driver's side to see if the noise moves with the lifters?
[QUOTE=johnta1;6193679]When cleaning the block, were the oil galleys cleaned with a rod ran through them? (just boiling them out doesn't clean them)
A lot of blocks seem to have a huge sludge type build up in them especially on that side. (end of line basically) Block was well cleaned before I took it in and again at machine shop. I then checked it after again. Thanks |
Just to mention this since I didn’t before. Another idea is maybe it’s the lift of the cam. It’s the Stump Puller profile from SD Performance by ground by Comp Cams. The lift is about .587-.590. When observing the lifters thru their travel I noticed that there is barely any oil bleed out the top of the bores at base and low lift. But when the lifter gets to max lift the oil flows very well. Possibly the lifters are collapsing at this point especially the last 4 lifters in the oil flow of the right side galley. They all look the same flow while turning over the engine and priming the pump with a drill. 60 psi oil pressure all the time. Just an idea. |
Do you have the 'so called' "Distributor Gear Oiling Hole" drilled in the threaded plug hidden by the rear core plug to that oil gallery?
The engines sometimes get an "air pocket" in the oil gallery between the solid rear plug and the last two lifters, or four lifters in some rare cases, and those lifters make noise. Drilling a .030" hole in the rear plug in a vice and then installing the plug in the oil passage now oils the distributor gear somewhat AND also allows any trapped air in the gallery to be forced out of the passage so that the lifters all see solid oil flow from that gallery. Food for thought. Tom V.
I have run the Stump Puller in 2 diff engines with the Shaver lifters.Tom
The hotter the oil gets from start up the louder it gets. So flow does have an effect on it. |
I posted about this on GTO forum and came back here to see this thread.
I asked (over there) why no one ever puts a crossover ,under the valley, from the rear left lifter galley to the right rear. Would that not fix any oil starvation issues...Period /??? Of course it would If the block is thick enough to support it, you should be able to drill and tap ( 1/8 NPT) and shove a fitting in it and run a piece of tubing to the passenger side galley from the left ( drivers side) and effectively match the flow/pressure across both sides.Effectively putting both galleys at the head of the oil feed. This was a fix I have pondered a few years ( actaully quite a few) I am suprised no one has done this knowing what we all know about pontiac engines. I am going to look at the galley thickness on the next build I do to see if just exaclty that can be done. It might be a while, but I will be checking. Anyone else who may have a block laying around, please take a gander and post up if you can. My blockk is at the machine shop (about 45 minute drive) so I wont be rushing over to sonic check anything soon ..LOL |
There are a few people on FB, that Jim Lehert built engines for and he is using the LS hyd roller lifters with a ford spider.
These combos have thousands of miles on them. |
Did this drilled out threaded plug come from the factory or is something engine builders do ?
No, just a good mod from Jim Hands book, or yes , what some good builders do.
The Following User Says Thank You to LATECH For This Useful Post: | ||
The drilled out threaded plug modification is mentioned back in the late 70's in the H-O Pontiac High Performance book. A do it yourself or you can buy them.
Example...... Butler 3/8" Pipe Plug, Passenger Side Oil Galley, Drilled PIO-PP475 .
#38
at the front of the block and remote lines to feed more oil to the front of the block or came up with a system like you have described. My opinion is it is better to take the oil flow from the rear of the block (near the distributor) or from the Oil Filter housing to feed other things. Like Superchargers (Vortech and Paxton) or Turbos, or in your thread passenger side lifters. Tom V.
#39
Add another vote in the "20w50 is a bit thick" column, but I don't think that's your issue.
I would be checking clearances and wear points. Regardless if this is your first or five thousandth Pontiac build, I'd tear the top end down to inspect. I'd be checking push rod to push rod hole clearance, rocker to valve cover clearance, rocker tip to valve tip geometry, spring retainer to valve seal clearance, even the run out clearances on those roller lifters. Gaskets are a whole lot cheaper than the parts you're running the risk of ruining by continuing to run that engine with that malfunction. |
#40
Not on snoopbook. Can we get some more info on that. I remember a thread about that spider. Wondering how it all worked out.
