Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
1962 Performace 4cyl
Rebuilt with less than 2000 miles. 194 + .030 pistons, crank .010/.010, edelbrock d port 72cc heads, custom 4 barrel intake made from edelbrock performer intake, holley 600 vacuum secondary carb, 1.65 roller rockers with tall valve covers (needed to trim heater blower housing). Runs well, in the car now, moving to v8. I do not have the extra heavy flexplate/flywheel.
$2500 or best offer, local pickup in Barboursville, VA.
1970 Firebird 3200lbs - CVMS built, pump gas 461, 3.89 gear 29.5x10 inch tire,... 10.40 @ 129mph. |
Have any info on the cam specs, roller or solid, stock rockers or 1.65, internals stock or arp, and updated oil pump, as well as balance rotating assembly, cast pistons or aftermarket and brand
Yes sir, stock cam flat tappet hydraulic with 1.65. Stock rods with ARP bolts, stock replacement oil pump, balanced assembly, sealed power 288p cast pistons. Very much stock aside from rockers, heads, and intake. I can send a video of it running, if interested.
-Greg
Will separate head/intake from rebuilt stock block. No reasonable offer refused.
I am interested, do you have a video of engine running? Maybe interested in complete, or just the top end. Thanks😎
Pure Pontiac Power!!! Picture of my actual 69 Judge racing in 1970. Rare Espresso Brown Ram Air III, 4 speed, manual steering with power disc brakes and factory build sheet indicating 4:88 special order rear axle. |
I will get a video, no problem.
