Old 03-19-2021, 02:25 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Launch in 2nd (Turbo 400) on the Street?
Hey Everybody,
I want to have some fun - some minor tuning on the street - in between getting the track:
Can I launch in second - T.400 with a brake without hurting the transmission?
Well - I do have a neighbor with a Chevelle - So -
315 /60 BFG non-sticky tires, ladder bars, good shocks, etc. 3400 lbs- (1.41 60's at the track with MT 28 x 10.5W.)
Thanks, Craig
Old 03-19-2021, 03:23 PM
mysticmissle's Avatar
unless your t brake is set up for second gear leaves, the answer is no.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-24-2021, 07:12 AM
taff2's Avatar
taff2 taff2 is offline
You can launch off the footbrake in second if you want, without doing any damage
Old 03-26-2021, 08:24 AM
ErikW's Avatar
ErikW ErikW is offline
What he said. Otherwise just foot brake it. The street probably won't hold a transbrake hit anyway.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 03-29-2021, 06:23 PM
JSPONT's Avatar
JSPONT JSPONT is offline
All depends, I can leave on my 28x10.5 slicks on 5-7 psi and get a decent 60'.
Some brakes do not work in 2nd as stated. You won't hurt anything leaving in second.
