Old 04-03-2021, 01:43 AM
ta man ta man is offline
What cylinder heads and compression?
Stan Weiss's Avatar
2 400 ci Pontiac engines. First one has 13.5:1 cr and has peak cylinder pressure of 1350 psi. Second one has 9.5:1 cr and has peak cylinder pressure of 950 psi. @ 100 ATDC on the power stroke the 9.5:1 cr engine will have the same cylinder pressure as the 13.5: cr engine. Note for this example both engines have their peak cylinder pressure at 12 ATDC.
Stan
Pontiac Pump Gas List
Old 04-03-2021, 06:46 AM
To me there comes a certain point in solid roller lobe function where the only benefits your getting by doing so is reduced fiction and milage life.
Old 04-03-2021, 07:10 AM
Here’s a informative chart from DV’s second book on BBCs in terms of the amount of overlap needed, and the BBC is a lot like 455 in terms of its not so great rod to stroke ratio and it’s need for far better breathing’ heads to produce rising power above 5000 rpm.
And yes, overlap and the placement of the overlap plays a part in breathing that shouldn’t be overlooked .
I wish I could posted up the instructions bigger in my second picture for easier reading, but that’s the best I could do!
ID:	564003   Click image for larger version
Old 04-03-2021, 08:40 AM
I've asked Butler, and await their guidance. The ideas here seem to gel well, and that off-the-shelf might be probable.
I've associated low duration cams with pinging. And cam that are just a bit too much with ping-free operation on 87 octane. In this case i will have a 9.0:1 long block to place the Roller, and a 10:1 Spare to place the 236/244 Flat HYD per below.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 04-03-2021, 09:17 AM
Steve, can you repost the Chart ahowing the leftside Compression ration? Thanks!
Old 04-03-2021, 09:19 AM
Yes. With snowbirding across 720 miles each way, the goal is mileage life.
Old 04-03-2021, 09:29 AM
Opp’s, sorry!
Here it is for ya!
Old 04-03-2021, 10:55 AM
Jay S's Avatar
Jay S Jay S is offline
Butlers will likely be suggesting those comp extreme marine profile I mentioned.
Looking at Vizards overlap chart we have been pretty far down the chart on some engines and still had milage in the 20s. Not saying his chart is at all wrong, but if you follow it to the T and are trying to get milage you will likely end up with a tractor engine. We have ran 70 to 80* of overlap and not seen much change in the milage. The cams all had pretty late EVO events.
Kind of what Stan posted, EVO doesn’t seem to drive the cylinder pressure that much. In very simple terms. Work=F * s. Force x distance. We have had better fuel economy increasing the (s) in that equation with the later EVOs, then paired the intake profile and overlap with the cid, compression and head flow. Don’t necessarily have to have a smooth idling tractor engine to get good economy.
Old 04-03-2021, 11:24 AM
So, i am sold on the 4.21" Stroke for Street, and MPG mileage, even with towing (like any sort of incline-uphill). The matter of great MPG versus cubicfeet/mile is dealt with by gearing/overdrive and EGR. EGR is that neutral filler gas (nitrogen) that makes a 455 run on the air of a 326. Air//fuel ratio being locked to 12:1, EGR allows a rich enough burn for power and great MPG.
All that goes away when "flooring it"!
That said, and out of the way, the parameters to allow 87 octane fuel for making ping-free power and performance app to favor the low/medium compression with EGR from cam overlap. I have sketched some Driver-controlled EGR schemes to tune-in the best EGR while on the highway, to compliment what-ever the cam is-or-isn't doing well enough.
Old 04-03-2021, 11:36 AM
Well I think that we can all agree that if a fuel mileage goal needs to met, then that will always come by means of average best numbers,
As in for example the most torque produced in the least amount of rpm between 2000 and 3000 rpm, with good power up to let’s say 4500 rpm for down sifted up stiff grade climbs and passing moves while towing.
Old 04-03-2021, 12:08 PM
"QUICK-SILVER" "QUICK-SILVER" is online now
This thread needs the intended cruise RPM really bad.
Clay
Old 04-03-2021, 12:15 PM
GTOLou GTOLou is offline
I have been REALLY happy with the Stump Puller!Have it in my 434 RA V.70 MPH at 1900.Tom
Would guess the stump puller lift is too high (can't remember it offhand) for HIS wants/needs. BTW - what lift are we talking about?? And..why the want for low seat pressure on a HR?? Heads already set up for that???
I also run a Stump puller in a low compression 455+ w/ low enough compression to run 87octane - and yes. A great cam. Aluminum heads, etc.
Old 04-03-2021, 12:31 PM
Stan Weiss's Avatar
Steve,
I don't have the book. But from working with David on his TMC / Torque Master Cam program (I did the computer programming). I would have to believe there should also be a LCA chart in his book also.
Stan
Old 04-03-2021, 12:36 PM
This would be my choice something similiar..what I would want is to make the engine efficient at cruise and the higher lift will not hurt.
I'm not why the OP is afraid of lift..this isn't the old days..modern engines have lift.
If aluminum heads were in the budget..combined with a cam similiar to the stump puller with an overdrive it would be 20mpg plus at 70mph.
Old 04-03-2021, 12:56 PM
Stan Weiss's Avatar
While it does come down to lobe design. But in must cases the more lift for a given duration the more velocity and acelleration the valve will see. Mark put some limits on what he wanted for valve spring pressures.
Stan
Old 04-03-2021, 01:14 PM
darbikrash darbikrash is offline
Originally Posted by Jay S View Post
Best results seem to be an asymmetrical intake profile with more seat timing, and the exhaust can be a symmetrical profile that is more aggressive and less seat timing. Usually see a drop in exhaust temps for heavy towing. It helps the exhaust valve spend extra time on the seat to transfer heat. .
^^^This^^^
Take a page from International Harvester, a typical cam spec for their 345 CID motor is 188/178 @ .050, lift .440/.395. I think overlap works out to around 39 degrees.
The 10 degree lower exhaust duration is specifically to promote heat transfer off the valve. You might consider adjusting the intake duration upward to match the increased displacement of the engine, but maintain the 10 degree lower exhaust duration
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
  #38
Old 04-03-2021, 01:27 PM
Stan Weiss's Avatar
Originally Posted by darbikrash View Post
^^^This^^^
I would be interested in what the intake port flow to exhaust port flow ratio is for that International Harvester engine.
Stan
  #39
Old 04-03-2021, 03:05 PM
This is what DV has in that same book Stan.
  #40
Old 04-03-2021, 03:33 PM
Stan Weiss's Avatar
Steve,
Thank you
Stan
