79-81 T/A rear disc brake caliper brackets
I have a pair of rear disc backing plates or cliper brackets off a rear end I bought no other parts. looking for $40 for the pair plus shipping- include 8 mounting bolts
were off a Texas car and are not pitted - should clean up nice please email me for pics rwhoag1969@verizon.net as I am not on this board very often thanks PY! |
backing plates
EMAIL SENT ON THE BACKING PLATES
still available
these do fit in large flat rate box that's 15$ to ship - how about 50$ shipped for these Paypal is accepted |
Still got 'em?
2001 Pontiac Trans Am WS6, 6-Speed, LS6 block, TEA LS6 heads, 4" SCAT forged crank, SCAT H-Beam rods, 226/234 cam, McLeod RST clutch, SLP Lid, SLP Power Flo Catback 1980 Pontiac Trans Am Y-84 Bandit WS6, 455 (.030 over), #96 Heads, Hedman headers, Wolverine 234/244 cam, Performer intake, Holley Sniper "Need a car to run blocker. Speedy car. Speedier than that....." |
caliper brackets
first set is sold now i have just picked up another set last saturday
these have some rust on them but not bad 50$ shipped please email me at rwhoag1969@verizon.net as I am not on this board very often |
bumping up who wants rear disc brakes?
what years of the 2nd gen F body rears do they fit? (I know 79-81)
67 Aquamarine vert,matching int,400/335,4spd,posi w/411:1,headers,Edelbrock P4B,hurst shifter. Starting resto soon |
Brackets will fit any 10 or 12 bolt housing for a second gen probably even most A bodies but have staggered calipers to clear the staggered shocks on the TAs. Need a 2.75" distance from axle flange to rear end flange. I;ve got a set on a 12 bolt with weld on ends from Moser.
more brake brackets
I have another set of rear disc brackets I bought when I was in Phx visiting mom, these are pitted and not the prettiest but will work just fine I even tapped caliper threads out because calipers were long gone
I can text pics later if needed, email or text 469 two three three 7142 thanks 45$ shipped |
CAn you post some pics on here so we can see what were buying ,, Thanks Rex.
old thread, another pair of caliper brackets available 50$ shipped
please email me for pics rwhoag1969@verizon.net as I am not on this board very often I have pics on my cell text if you would like to see them 469-233-7142 |
Disc Brakes
I am looking for what ever the e-brake cables hook to at the back of the disc brakes. I am working on a 80 T/A and the cables are just hanging there with nothing to hook them up to. If you have the parts that would be great.
I dont have any of this just the caliper brackets and bolts |
I have another set of disc brackets available $50 shipped
Any extra caliper lever E brake return springs?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Joe I got nothing but may ask out if someone could give spring dia and length you should be able to get something workable at True Value hardware
