I would guess if you were driving over 10K miles / year high lifts may well be an issue. FWIW I ran .680” for almost 5,000 street miles, mostly city but a fair amount of 3K plus RPM highway runs including to Norwalk and back a few times, and the guides showed no wear on a tear down. I was pleasantly surprised.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
Stan
In a running engine with valve train deflection and hydraulic lifter bleed down at rpm actual lift at the valve is probably closer to .600”. Assuming the cam did lift the valve the theoretical .6435” I still wouldn’t loose too much sleep over it as far as longevity is concerned. Send it!
Fwiw…..not been mentioned but should be considered
I’ve seen plenty of forged rod, cast crank setups making decent power and having fun until the stock cast crank breaks in half… There is NO free lunch !
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
I’ve never yet seen a factory cast crank snap in half if it had
1) passed a Mag test. 2) not been subjected to well over 600 hp. 3) not been pounded on by detonation. 4) subjected to a combination of 2 and 3! 5) not been cut down from 3.250” to 3.00” mains. 6) the same as the above but not run with a Olds thrust bearing and had been welded up.
