Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
#461
#462
#463
GONE GONE GONE
Intake is gone.
"If we're all thinking alike, somebody's not thinking". - Gen. George S. Patton "Fat people make lousy revolutionaries". - Me '67 Grand Prix 400/400 Cameo Ivory '69 Firebird 455 BW ST-10 '69 Grand Prix J 455/400 Midnight Green (SOLD) '66 LeMans Ex-Drag Racer Parts Car (SOLD) '66 TOO DAMNED RUSTY GTO Project (SOLD!) '70 Firebird Esprit (SOLD) |
#464
68-72 Olds A-body 10 bolt rear. 2.78 pegleg. Been under my car since I've owned it. Just pulled today. If you want to pick it up it's yours.
Sent from my moto g stylus (2021) using Tapatalk
Greg Reid Palmetto, Georgia |
#465
Might pull the axles & measure the diam of the axle bearings...
Rear is a '68-70 Type "O" Olds, & from look of the bottom of the shock mount brackets, originally from a VistaCruiser or flat top Cutlass wagon.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
#466
Thanks oph. I've tried several times to ID this axle but the stamping may be wrong. It's clearly 'T1' or 'TI' but l've never been able to find that axle code anywhere for the 'O' type rear. I'll measure a bearing later today if l get to it.
#467
Bearing opening measures 2.85". Code T1.
#468
8 pontiac 455 rods, factory bolts with .030 L2359 trw forged pistons. I think that part number is forged. They are free. If no interest gonna toss them. Once I saw the bearing wear on this engine the while I’m here thing took over and all I re used is the crank. Go figure.
#469
The Following User Says Thank You to gobrdgo For This Useful Post: | ||
#470
Rods/ pistons gone
#471
78-87 G body rear heavy duty variable rate coil springs
Brand new I think these are Moog, save them from the recycle bin!
https://forums.maxperformanceinc.com...94#post6303694 |
#472
58-60 370-389 Engine gasket set
Got these when i bought an engine. I have nothing that can use these so I'll send them out for the mailing cost. Best Gasket engine building set for Pontiac 58-60 370-389 Engine gasket set. If you need them they're yours
#473
PM sent.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
#474
Thankyou, yes I have an engine in progress. Let me know how much and the money will be on its way. Dan Merritt, Kingman Man, 1780 E Develin Ave, Kingman, AZ 86409.
1955 Star Chief 4 dr w ex w/c lift 1964 Comet 4 dr 1989 Cherokee 4 dr 2000 Dodge Grand Caravan w w/c lift 2000 Kia Sportage 4 dr |
#475
pm sent Batman
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!..... |
#476
Mallory unilite photocell
I got this with the distributor I gutted to make a cam sync. Don't know if it works. If you know a method to test it, I can probably do that. Yours for shipping cost. CONUS only, I'm not dealing with international shipping to donate something... OR, I'm in the Houston area if you're local you can pick it up.
#477
I've still got a complete 350 2-barrel engine free for the taking. I believe it's a '72. I drove it a few thousand miles with no problems. It's been in my barn for almost 20 years, but has been all together and still turns free. Has a standard-shift bellhousing and clutch/flywheel on it. Accessories (pulleys, alternator, etc.) are really ugly with surface rust and crud.
#478
64-65 Convertible top end cap
used, good shape - don't need.
#479
D port Zoomies - free
1.75" OD, made by local muffler shop. pretty rough but no leaks. free if you cover shipping from 29642
The Following User Says Thank You to lrust For This Useful Post: | ||
#480
400 crank from a 75 481988 block
7 pistons / rods from the same block checked two one was S one was p both also said 3 8 400 rods with pistons checked two both said either 7 or L Have had the stuff for over 10 years the block was used for a project Pickup only in Glendale Heights IL
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
