Old 10-22-2021, 02:20 AM
NeighborsComplaint's Avatar
NeighborsComplaint NeighborsComplaint is online now
Yeah, my bad! Fat fingered into the wrong thread!
Triple Black 1971 GTO
  #82
Old 10-22-2021, 02:24 AM
Vckline313 Vckline313 is offline
It happens
Sent from my SM-G996U using Tapatalk
  #83
Old 10-25-2021, 09:11 AM
Originally Posted by dirtbird5x View Post
I personally believe you have a tuning issue… has your HEI been worked to adjust the advance curve…
Also what about ignition setting at idle… as far as heads the 5C heads are actually really good so IMO until you can upgrade to Edelbrock
What would you or anyone else reccomend me being "all in" at? I bought a msd distributor recurve kit I will be playing with soon
I have vaccum advance plugged into manifold vaccum now as well
  #84
Old 10-25-2021, 09:42 AM
Stan Weiss's Avatar
It was ask for a couple of time but I don't see that a Cranking Compression Test was ever done on this engine.
Stan
Originally Posted by Vckline313 View Post
No none has been done
Why not?
Stan
Pontiac Pump Gas List
  #85
Old 10-25-2021, 10:01 AM
Why not?
Stan
Haven't bought the tool to do it
  #86
Old 11-14-2021, 09:20 PM
Ended up finding the original owner of my car on Facebook. He said car has a ram air III cam, car was bored over 60 over balanced and blue printed he said the heads were worked but dosnt remember the specifics and compression was 9.5 or 10 to 1
  #87
Old 11-14-2021, 10:12 PM
padgett's Avatar
padgett padgett is offline
" Haven't bought the tool to do it " $14 bucks too much ?
Web Site
  #88
Old 11-15-2021, 08:50 AM
Correct
  #89
Old 11-15-2021, 02:23 PM
P@blo's Avatar
P@blo P@blo is offline
$10 on sale and you might be able to wrap your cast iron heads in aluminum foil with the $4 you have left over.
  #90
Old 11-15-2021, 11:11 PM
Jay S's Avatar
Jay S Jay S is offline
Rough idle with a RA 3 sounds like it describes a 744 cam.
If this is correct the aluminum heads won’t gain much with out a cam change too. RA3 744 cam only has .406” lift. The bigger ports on Aluminum heads just start to get going at .4” lift.
To get a 400 with 5C to 9.5-10 compression would either take some domed pistons or start out with small chamber 5c’s with a lot of milling to get the cc’s down. Both are possible, but I would be surprise if the compression is that high. By the way the performance is described it is more likely the compression is low 8s and the 744 cam. Fwiw
