1970 GTO underhood harness routing
Still piecing together my 1970 GTO. As documented many times before, I got it as a stripped wreck with the front clip missing; the wire harnesses had been cut. I purchased new American Autowire harnesses, but I don't know the routing. I'm hoping someone out there has some clear pictures so I know where to run & clip things. Any photos appreciated!
I don't have photos of a factory harness but do have an assembly manual. Are you looking for firewall to engine, or firewall to rad support (or both)?
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Both.
I have the assembly manual myself, but its a bit fuzzy hard to read....that's why I was looking for pictures! |
See if these are any clearer than yours.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire Last edited by mrennie; 11-04-2021 at 09:37 PM. |
Chapter 12 in the 70 Service Manual has many pics of wiring routing.
Check these out.
Those drawings are way better than mine! I bought a copy of the assembly manual off Kijiji & think it was a set of photocopies...it's really hard to read.
Thanks!! |
I had one of the crappier manuals as well when I started. Pretty much useless.
Inline Tube has since been selling a higher quality version which is what these pics are from. The pages are blue instead of white.
Oh to have a nice assembly manual....said the guy with a '64! Lol
Back under the hood....
The replacement harness has 2 ground locations, One is a smaller connector, takes a sheetmetal screw. From what I could see (looking on the inter-web) it attaches to the body right by the fender mount on the firewall. Lo & behold my car had a hole there, so I assume this is correct? Second ground is a much larger connection for a 3/8" bolt. I assume this grounds to the cylinder head or engine block? |
I'm going by memory so $0.02...
The larger eyelet goes on the back of the driver side head, and the smaller one goes under one if the screws that hold down the horn relay.
Great, thanks!
