I believe the valves were supplied by Kelsey-Hayes and did similar vehicles. I don't know that any were the same part or substitute, but may have found their way into a few non-popular models for collectors. Of course, using the same casting doesn't tell of any internal tweaks, but they'd need to identify the differences somehow. The threaded lines may not be the same either. It may be easier to reverse-engineer, find out which models use the same brass block offered now and if internals etc match.
A buddys getting 3 birds in to part out, if you can wait. Ones a 1980 recro ta.
I won’t mention names, no one seems to know the guys that are always at the Big swap meets ��
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8 Flakes pause pause F ire B irds 🇮🇱 |
what is a 1980 recro ta ??
Its the one I may buy the seats from.
Never seen an 80 Recaro's
I have seen an 81 with factory Recaro's
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
Omg. It was a typo.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Sorry for hi-jacking thread but does anyone know if the Cadillac 4 wheel disc proportion valves are the same as the Pontiac 4 wheel disc valves? There is a guy who has one for sale from a 1980 Caddy and he says it is the same as the Pontiac proportioning valve. I actually looked at it but I do not see any part numbers on valve.
going bandit-Reynolds style |
The Caddy Eldorado is a FWD car, different weight bias and characteristics.
Maybe if the reference being made to 1975-79 Sevilles, which was essentially a Nova in Cadillac trim.
Original 79-81 4 wheel disc Bird prop valves were cast iron. Over the years I've pulled & used the 4 wheel disc prop valves off quite a few '78-79 Sevilles. Also have pulled numerous nice used '79-81 T/A 4 wheel disc prop valves & even a few nice appearance original 4 wheel disc boosters. For my '79 w72, am reusing a very clean original 4 wheel disc booster i pulled 30 years ago off a '79 403 car.
marketed at least 20 years ago, the brass construction Delco Morraine 4 wheel disc prop valves were first used I believe in early 90's GM 4 wheel disc applications. Then the aftermarket got involved having their knockoff brass prop valves & boosters made for the bug smacker crowd.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 01-26-2022 at 02:21 PM. |
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
