My new oil pan...
I had no idea Stefs even built us a pan until I saw a post a while back by Dragncar...
Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
That’s a sweet pan I didn’t know they made one either
What’s the side bung for up behind the starter ? Almost looks like a turbo drain back location.? Or is it for dry sump?
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
It’s an oil drain back from my Eheads. The other side will have one as soon as we mock it up and see where we can put it...
The Following User Says Thank You to 69Goat1 For This Useful Post: | ||
Nice pan. I had them put in a provision for a dipstick on pass side and a 1/8" bung with baffle just below pan rail for vacuum fitting. I should have had them put in a oil return fitting just forgot to ask. They sent me some weld in bungs if I want to do it myself. But running High Ports so I do not think I need one.
I made my own oil pump pickup for a pump I enlarged to .915 on suction side. Did you buy the Steffs pickup ? Are you planning on running a gasket or just use The Right Stuff and no gasket like some do ? One thing I have done is buy I-Js teflon crank scrapper to add to it all. You can actually touch the crank with this scrapper. Kind of expensive at 230$ but if it gives me more power its worth it. I-J told me this scrapper can add 3, maybe 4% horsepower which is a lot if you think about it. A regular steel scrapper gets you 1-2% more horsepower he said. Aluminum block, she is going to be badd @$$. |
Nice looking pan.
Looks very similar to the pan I got from Moroso.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
The Following User Says Thank You to BDHABT For This Useful Post: | ||
I ran a similar pan from them for years. Nice piece.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
I need a pan , looks nice . Does that pan fit stock chassis/ crossmember A body cars ? How long did you have to wait for pan ?
505 CID, 3560 lbs,Tiger heads, NA. 8.99@149.8 mph, 1.29 60', stock suspension |
I had one on my tube car. It was a very nice piece. They make good stuff.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
They will not have the built in crank scrapper like a Canton. But how close could you get a crank scrapper built into the pan anyway? Just put in a pan rail located crank scrapper on the kickout side and you have a better scrapper, clearanced right vs the Canton . I first called Canton but it was during Covid and the wait time was huge. Called Stan at Steffs and my pan took 3 weeks. Great to deal with. |
Yes, fits stock chassis A body. Mine was quoted to take 2 months but in actuality it was nearly a 3 month wait due to materials and labor issues.
69goat1 , Dragncar , thanks for the info . I made a kickout for the canton 452 pan and have the Teflon screen from Stef's, still working on it . Might just order the Stef's pan and save this one for a future project .
Johnny, is the blower going on it??? Hope you can make Great Bend. Last year was pretty ho-hum with that long oil clean up...
Hoping to make Great Bend and the POCI race in July in Tulsa...
