Old 05-30-2022, 12:44 PM
Zooguy Zooguy is offline
Default Speaker removal help please
66 Star Chief executive
How do I remove the speaker out of the dash?
Old 05-30-2022, 07:20 PM
Heybuck's Avatar
Heybuck Heybuck is offline
You need to remove the dash top.
Take off the polished aluminium trim on either side of the windscreen (inside the car), there are screws holding the dash top along the front but ALSO, you might find there is a screw you have to access from the scuttle. In the middle of the car.
Not a difficult job. But if you are replacing the original speaker, make sure you get one with the correct ohms. My (bad) memory tells me its an 8 ohm speaker.
To laugh at men of sense is the privilege of fools.
