Old 07-03-2022, 03:20 PM
imposter's Avatar
imposter imposter is offline
Default 1966 Bonneville
just found this gem been in a garage for 39 years not sure where to start or put it the interior is pretty much perfect and its dry underneath who wants to restore it for me
ID:	593643   Click image for larger version
ID:	593644   Click image for larger version
ID:	593645   Click image for larger version
ID:	593646   Click image for larger version
Old 07-03-2022, 03:23 PM
imposter's Avatar
Default bonneville
gonna need some parts i want to put a GP nose on it as well
Old 07-03-2022, 05:04 PM
misterp266's Avatar
Thought the interior was green until I saw the pic with the door open. Looks like you could give it a scrub and go!
I have some GP grille shells and also an NOS tail panel (not the trim, the sheet metal) if you want to make it a 4dr GP.
" Darksiders Rule "
Old 07-03-2022, 05:14 PM
imposter's Avatar
sounds like a plan, i still have to move 4 cars with 16 flat tires to get to it first
Old 07-03-2022, 05:45 PM
MPKind's Avatar
MPKind MPKind is offline
Leaving cars as-is is a big trend these days. That car is a perfect candidate. Not rusty, very complete. Detail it inside and out, new rubber, address any mechanical issues and drive it. I would not take that car all apart just to make it “nicer”. It’s a 4D HT, which really helps vs. a 4D Sedan, but it’s not a 2D or a conv. So chose your path wisely.
Pay someone to detail it, buff it out and all that. Have a trusted friend that knows engines and chassis determine what needs attention. New tires, belts, hoses (not the flex type), brakes etc.
Took me over 20 years to do full frame off on my 65. You can have that car running and driving in a month or less and enjoy it. You’ll get a lot of lookers at shows if it u restored vs. becoming a trailer queen.
65 Catalina 2D Post
The Following User Says Thank You to MPKind For This Useful Post:
Old 07-03-2022, 10:03 PM
imposter's Avatar
i do plan to leave it well most of it the nose is pretty shot as far a corrosion i'll keep updating
Old 07-04-2022, 07:35 PM
Heybuck's Avatar
Heybuck Heybuck is offline
Talking
What a ripper car. Love it
Options I can see are Automatic Temperature Control, Power Windows, Hazard warning lights, Opera lights, Floor mats.
What else????
Ian
To laugh at men of sense is the privilege of fools.
The Following User Says Thank You to Heybuck For This Useful Post:
Old 07-08-2022, 07:48 PM
imposter's Avatar
need 2 steel 14" wheels local would be nice
Old 07-10-2022, 07:51 PM
Redpiston Redpiston is offline
Looks like you got original keys. Sure would like to steal that dash pad. I could use it.
Old 07-11-2022, 02:23 PM
mr67gp mr67gp is offline
Congrats - I saw this on CL a while ago. I can smell the mold from here . . .
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 08-20-2022, 07:41 PM
imposter's Avatar
Default free
she's free from the dungeon now whats next
ID:	596854   Click image for larger version
ID:	596855   Click image for larger version
ID:	596856   Click image for larger version
ID:	596857   Click image for larger version
Old 08-20-2022, 07:46 PM
imposter's Avatar
Default indian saved
she's out from the darkness after 40 years
ID:	596859   Click image for larger version
ID:	596860   Click image for larger version
ID:	596861   Click image for larger version
ID:	596862   Click image for larger version
Old 08-21-2022, 03:01 PM
Looks to be incredibly straight. Good find! You do own a pressure washer, yes?
Dr. Thomas Sowell
Old 09-30-2022, 11:16 PM
imposter's Avatar
Default making
progress report amazing no rust underneath, all suspension and body bushings are soft, definitely leaking oil for a while from the motor, it was missing 1 converter bolt and the weight on the snout of the converter was broken off it must of vibrated real bad but i bet this thing never went past 50mph 98k on the clock
ID:	599642   Click image for larger version
ID:	599643   Click image for larger version
ID:	599644   Click image for larger version
ID:	599645   Click image for larger version
Old 10-01-2022, 08:40 AM
Bill Hanlon's Avatar
I've never seen red stripe tires on a boat this large.
Old 10-01-2022, 11:31 AM
imposter's Avatar
i had those in the garage the front wheels were rusted flat it does look cool im thinking of goldlines for it H-78's
its a shame someone painted it at some time in its life being it never went far
Old 03-20-2023, 09:30 PM
imposter's Avatar
Default Progress Report
making some progress installed a 2.93 posi, some custom spohn rear control arms, prothane front bushings and a hugggge front sway bar, almost rolling on her own
ID:	609255   Click image for larger version
ID:	609256   Click image for larger version
ID:	609257   Click image for larger version
ID:	609258   Click image for larger version
