Old 08-25-2022, 01:39 PM
70ra455's Avatar
70ra455 70ra455 is offline
Default Parts Galore
PLEASE REFER TO THE ITEM NUMBER.
MUCH MORE COMING!
Shipping extra. P/U in metro Detroit for free.
1. (3) 1958 NORS Pontiac Tail light lense. 2 have the NORS trim ring.* Glo-rite $50 for all 3
2. NOS 1968-1972 Pontiac LH Door handle great condition $30
3. 1966 (65?) Full Size (except GP) Vent window reveal passenger side ... nice condition $20
4.* 1951-52 Pontiac NOS gauges.* 2 water temp and one alternator ... $50 for all 3.* Use for your hot rod!
5. 1965-68 full size Auto Shifter gate slide.* $10
6. 1970-1972 GTO NOS Coat hooks $15
7. 1968-1971 GTO a/c blower motor relay New.* $25
8. 1968-1971 GTO horn relay cover.* Original.* $25 each both for $40
9. NOS Pontiac 63-74 condenser and rotor $12
10. 1966 Full Size NOS Pontiac Stop Package front wheel (2) $15 each or $25 for both
11. Seat tracks.* $100 for the whole lot
12. Misc brackets (seats??) $25 all 3.
13. Gas tank ... I'm told 1967/68 full size ...* you determine!* Comes with sending unit.* $50
14. 2 Rally Wheels 15×6. 5×5"* KY code 1971.** $150/pr
15. 2 Rally Wheels 15x7 5x4.75" $150/pr
16. 1 Rally Wheel 15x6 5x4.75"* $75
17. 4 Rally Wheels JT* (2)12/5/69* (1) 1/13/70. (1) 2/20/70. 5x4.75" blasted and primed. $350 for matching date pair* $150 each for the other 2
18. Pontiac hub caps 14" buy all 11 for $75
19. 1970 GTO Convertible glass ... left and right door and rear top.* Factory original tinted glass.* $400
20. 1970 GTO Choke Thermostat all ex. RA4* 7040097* this is the correct 1970 GTO 4bbl and RA3 part number* $150
21. Pontiac original v8 engine lift hook. Shaped different than repops.* $10
22. Pontiac original speaker.* Needs restored. Part #7300614* 1966-1972. $20
23. Pontiac 1969-1972 Gas Pedal. New Year One repop.* $26 in Year One cataloger.* $20 here.
24. 1969-1972 GTO a/c duct, LH Outer, part #9782386.* $50
25. EIS remanufactured brake shoes 1968-72 GTO and other models* $30
26. 1971 GTO, 70-71 Firebird w/w fluid jar, part # 3961557.* With attaching bracket. Great condition.* $45
27. 1970 Ram Air 3 exhaust shroud.* Original and fast superior shape and fit to repop. Great condition.* $600 on ebay $300 here!
28. 1970-1972 GTO/GP Part #546427 and 1970 GTO/GP Part #486011 upper panel center.* Excellent shape.* $25 each
29. 1970-1972 GTO left/right upper Cowl grills. Original $50
30. 1969-1972 GTO Ashtray and bracket.* Original and MINT. No fit/ finish issues.* Use for show car.* $95
31. 1970 GTO Clock Delete. Original.* Great shape with attaching screws.* $35 ea.* (I have 2)
32. 2 used Pontiac Neutral Safety/backup switches.* For Automatic transmissions. See pics for condition.* Part #1993448 and #1994153. $15 each
33. 1970 GTO dash side l/r a/c deflectors.* Original and MINT.* I would say NOS but don't have the boxes.* For show cars.* $180
34. 1970 GTO all original and mint. Cigarette Lighter with 2 recepticles and 1 bezel and 1 heating element ($50 )***** Light Switch pull knob with bezel ( $25 )* Light Switch looks excellent and clean ($25 ) Windshield Wiper Switch check out how clean in back! Can be NOS? ($100)
35. 1968-1972 GTO Console box part #9790838 original with flocking in tact. Original hard shell plastic, not the ill fitting $75 repops. ($50)
36. 1970-1972 GTO tail light housings excellent.* Ebay just sold a pair for $129 plus $30 shipping!* I say $100.
37. 1970 GTO tail light lense LH.* Great condition.* No cracks in the lense.* $100
38. 1969-1972 Remote Mirror. Original nor a repop.* For a show car.* Close to NOS as you'll find.* $250
39. 1968-1972 GTO turn signal switch.* NOS. $25
40. 1970-1971 Pontiac GTO, GP* NOS rear seals* (2)* $15 each or $20 for the pair.
41. 1969-1972 Pontiac ignition Switch.* Used original.* Look very clean. Have 2.* $20 each or $30 for both.
42. 1970-1972 GTO wiper switches.* Used. $25 each.* $60 for all 3.
43. 1965-1966 GTO heater adjuster lever/knob. $20
44. SOLD!
45. I think this is 1970 GTO backup lamp harness with bulb.* You determine.* $15
46. 1970 GTO grill chrome surrounds L/R. $150
47. Pontiac NOS upper beam headlamp.* $10
48. 1969-1970 GTO turn signal bezels.* $30
49. SOLD!
50. 1970 GTO wiper arms original Trico.* $50
51. 1965 Pontiac, Chevy, Olds, Buick, Caddy New Convertible Pillar Post weatherstrips. $50
52. 1969-1972 GTO outside mirror.* Looks NOS. MINT.* $75
53. 1969-1970 GTO 4 speed neutral safety switch.* $30
54. 1970 GTO wiper arms original TRICO $50
55. SOLD!
56. 1968-1972 GTO License Lamp. Original lense with great silver paint.* Complete assembly with harness and blocking plug.* $30
57. Valve Stems with caps ... new.* $5
58. 1970 GTO Ram Air exhaust tubing.* NEW. Original style.** $45
59. 1966-1967 NOS Pontiac b-up switch mounting bracket.* $45
60. 1969-1970 Ram Air upper cage seal.* New.* $20
61. 1970-1974 GTO NOS radio interference shield.* $40
62. Carter 4bbl Choke pull off. New.* $15
63. 1968-1972 GTO original license lamp lens.* Excellent with silver paint intact.* Close to NOS.* $45
64. EIS drum brake springs.* New. $10
65. 1970 GTO grill emblem.* Used.* $25
66. 1970 GTO door handle with button.* Excellent chrome.* $35
67. Pontiac battery hold down?* Not sure of year/model?* $10
68. SOLD!
69. 1968-1975 NOS Pontiac Circuit Breaker $20
70. Pontiac NOS give box cylinder $40
71. Pontiac NOS 1969-1975 case and rotor glove box lock $20
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 08-25-2022, 03:45 PM
mr67gp mr67gp is offline
Sent you a PM on #13
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 08-27-2022, 05:43 PM
70ra455's Avatar
#2. NOS inside door handle SOLD
#34 WW switch and Headlamp Switch SOLD
#39 NOS Turn signal switch SOLD
