Old 08-30-2022, 03:08 PM
rememberfireball#22's Avatar
rememberfireball#22 rememberfireball#22 is offline
Default Shifter / Trans
Hey Guys, I need some help. My 68 GTO won't go into third from second. It will go from first to third fine and from fourth to third fine. When you try to shift to third from second , its like the shifter hits a brick wall. I I am unable to get under car due to physical problems. Does this sound like a trans problem or shifter problem. I have removed console and carpet to make sure there was no interference. thanks, Mike
1968 GTO Numbers matching 400 H.O. 4-speed 3:55
1964 T-Bird 46,000 Actual Mile
1928 Model A
2009 Lexus
1981 Dodge D-100
1976 Cadillac Eldorado Convertible
19631/2 Ford Galaxie Fastback
Old 08-30-2022, 09:37 PM
stevep's Avatar
stevep stevep is offline
Sounds like a shifter/linkage issue
Old 08-31-2022, 08:48 AM
Sounds like time for a Shifter Alignment: think a 1/4" Phillips shaft goes into the shifter hole for 2-3 3-2 H-Gate access, and the rod lengths are Thread-Nut adjusted for length.
