Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
sold car this was designated for, will consider selling short block and a set of heads.
virgin block fresh from machine shop jail, 55mm roller bearings, bushed 903 lifter bores, dry deck 4.31 bore ross pistons, 6.75cc dome, 2.35/1.9 valve reliefs, BWE rings already hung on the pistons which are on GRP aluminum rods Scat 4.35 stroke crank with SBC rods journals, crank is 10/10. 1967 bob weight balanced to 1/3 of a gram, FM main and rod bearings included comp cams 55 mm roller cam 270/286 112 lsa .521/.500 lobe Crower 903 offset, bushed lifters contact me if serious 19k will add pics and head details
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction Last edited by mysticmissle; 05-18-2022 at 09:15 AM. |
"A" for aluminum?
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Yes a for aluminum and expensive lol pics coming
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Pics
Pics2
Pics3
Pics4
Pretty much everything needed for short block, is included. Only thing I can think of that I need to order if o keep it is rear seal of your choice and head gaskets
I have a set of hiports at the shop being looked over and a set of tigers fresh from the shop. If you buy the short block you will have first choice of cylinder heads and I will keep the others. Hiports shouldn’t be too long before done. When they are I will make a decision on which motor is going in my gto and this aluminum motor may no longer be available
$18,500 consider trades towards a convertible pontiac or buick
A for Available
buy this and my tigers and have your fast and junk ready for norwalk
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
last price drop before it starts going together $17000 tigers/kre heads are no longer available in the package
drool...putting on xmas list
The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
Just curious, what compression ratio were you targeting in this motor ?
All depends on head Cc head gasket thickness and diameter
But we are planning on 14+ W 65cc heads
Thanks, currently have an iron IAII with hi ports in my 66 GTO but want to go all Aluminum. This is very cool but probably too much for what I’m trying to do in a predominantly street driven car
https://youtu.be/vz-l29omL70 |
The Following User Says Thank You to nmoreilly For This Useful Post: | ||
Bump
Available for Santa
Currently available
most likely last bump, before i start assembling, will consider (car) trades up or down money wise, in next 3-4 weeks
