Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
3 Solid Roller cams for sale with unknown specs
I have three roller cams that I bought off of members and never used. Unfortunately in my move I lost my computer that had all the cam specs on it.
The first cam is a Lunati, but I can not remember the member I bought it off of. The engraving on one end is 106E KZMP Lunati cams RRC. On the other end the numbers are 289356 93G1A. The second Cam is a Ultradyne cam I bought off of Eric Vogl known as GTO on here from Timmins Ontario, Canada. The engraving on the end is G3984 309/310 R6. The third cam I bought off of Mike Davis and is a Comp cam. The engraving on the end of this cam is 305-2 305-2 R10 F 0780. I know you can have a cam doctor done on them I am not sure how much it costs though. I know all of the lifts of these cam are under .700 with 1.5 rockers. All of these cams are supposed to be easy on the lifter bores for the duration at .200. $250 Each, plus shipping.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. Last edited by David Holmberg; 11-02-2022 at 09:06 PM. Reason: pricing |
More pictures.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4. |
GT |
No. It should be $250 each OBO. Sorry for the confusion.
Location?
Pasco, WA
I talked to Comp CAM and got the specs on one of the cams. It is a 110 LSA. Lobe lift is .360 with a duration of 272 @.050. Lash is set at .026 Hot.
All cams $225 each OBO Plus shipping.
UD lobes? only group I found with a 309 duration
NR100 309 280 0.4507 NR103 310 280 0.4271
Thank you Skip that helps a lot.
$200 obo plus shipping for these cams. We have a couple of the cams lobes figured out. The comp cam is listed above and Skip found information on the ultradyne cam lobes. Thank you again Skip.
Bump will consider reasonable offers.
Bump. $180 obo plus shipping
Bumping it on up. 2 of the cams have specs listed now.
Comp cam sold. Ultradyne and Lunati still available. 180 OBO plus shipping which looks like about $25.
Bump for Christmas.
TTT
Make a reasonable offer on a cam. The Ultradyne Skip listed the specs too and I know the Lunati cam was real close to the Comp and Ultrasdyne specs that were listed here.
Lunati cam sold. Still have the Ultradyne cam.
Thanks quick67bird.
Thank you sir. Pleasure doing business with you. I hope that cam sounds good and makes your car fly.
