73 455TA manual car exhaust manifolds
Hi all does anyone have a correct listing for manifolds.
I have tried online , Wallaxe site etc but doesn't appear to be a complete listing. I have a 490142-1 which may he RH, and a 480602, which may ge left but not sure. Not really too concerned with date codes at this stage, just correct casting as many span quite a few years cheers Edit, I also have a 9796992 7 as well, which looks the same as the 490142 except it doesnt have the outer bolt holes
Working on going faster (and now staying dry at the same time !!) Last edited by 455-4+1; 05-19-2023 at 08:59 PM. |
Pretty sure 490142 & 490143 are the original numbers for '72 & '73 Firebirds with any V-8 except HO's & SD's.
Ok thanks, will be on the look out for a 143 then, hopefully the other 2 I have for that side will suffice in the interim. It's a long term project
Working on going faster (and now staying dry at the same time !!) |
Here are early 1973 (cast 1972) and early 1974 (cast 1973) exhaust manifolds casting numbers.
So long, farewell. |
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post: | ||
