WTB Stock 1966 GTO Exhaust Manifolds
I’m looking to purchase a set of stock ‘66 GTO exhaust manifolds with decent seal surfaces.
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs 1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold |
Are you looking for correct dates or just manifolds that fit 66?
Stock 1966 GTO manifolds with reasonable wear of mounting surfaces is my goal. What exhaust manifolds do you have available for sale? Thanks..
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs 1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold Last edited by sixty8ragtop; 06-05-2023 at 04:44 AM. |
I'm pretty sure I have a useable set somewhere in the barn. However shipping on such heavy items will be expensive...I'm in 12603 NY.
I've got a pair that I would probably part with. They came with a '66 WT 389 4-spd GTO engine. Pretty crusty but mounting surfaces are smooth. Heat riser is free. Biggest problem is that one of the flange bosses is broken on the one without the heat riser. Someone was using a flat washer under a nut to seal it there.
The other thing is I'm still in recovery from major stomach surgery so might be a little slow getting things done. Just in case you can't find any you like.
Greg Reid Palmetto, Georgia |
Looks like I sourced a set locally.. Thanks to all who responded to my post.
The Following User Says Thank You to sixty8ragtop For This Useful Post: | ||
