Old 02-12-2016, 11:19 PM
Default Tri-Power Intakes - Identification
Post your pictures of various year Pontiac factory Tri-Power intakes, to help aid in identifying them for those who are looking to put together a Tri-Power setup. Also post pictures of the correct thermostat housing for each intake if you can.
Hopefully we can end up covering all of them from 1957 through 1966.
1959, casting # 532422
The bare intake weighs 39.45 pounds.
Correct cast iron thermostat housing for 1959, with built-in engine lifting loop. As you might imagine it's quite heavy, weighing in at 2.85 pounds.
Here you can see how the lifting loop configuration of the thermostat housing was copied in .150" to .175" thick stamped steel for later engines, attaching to one of the studs that mount the timing cover.
Old 02-12-2016, 11:25 PM
1964, casting # 9775088
The bare intake weighs 46.25 pounds. I'm betting this one's the heaviest of the factory Tri-Power intakes.
Correct cast iron thermostat housing for 1964. It weighs in at 2.00 pounds.
Comparison of 1964 Tri-Power thermostat housings, OEM and repro. The upper one with the raised pad under the casting number is the original piece. The repro piece is actually about 1/4" shorter (in overall height when installed) than the original.
Old 02-12-2016, 11:29 PM
1965, casting # 9778818
The bare intake weighs 34.80 pounds.
Correct cast iron thermostat housing for 1965. It's a lightweight at 1.40 pounds.
Old 02-12-2016, 11:31 PM
1966, casting # 9782898
The bare intake weighs 38 pounds.
Correct cast iron thermostat housing for 1966. It's a lightweight at only 1.50 pounds.
Old 02-14-2016, 03:06 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Default The only Pontiac aluminum Tri-Power
'61 SD Tri-Power
ID:	420777   Click image for larger version
Old 03-08-2019, 08:25 AM
Carmine Carmine is offline
Hi everyone. I have a tripower intake with carbs that I have owned for about 30 years or so. My intent was to rebuild it so I took the carbs off and apart, putting them in separate coffee cans. Never went any further with it. I knew at one time what that part number/date code was, but I forget. I can always get it again, but I think it was a very early 60's manifold. If I'm correct, would this fit on a '57 engine?? If not, what years would if someone knows?? Thank you, Carmine.
Old 03-08-2019, 09:28 AM
Sirrotica's Avatar
Pontiac first gen heads and intake are 55-60, 1961 will not fit the earlier heads. 61-64 are the second gen, and 65-79 are the third gen.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-08-2019, 11:15 AM
tom s tom s is offline
Brad,the 61SD heads are a one year bastard head.It uses the 55-60 water pattern but the intakes made for them use the X over water donut so require a 61 timing cover.Gets a little confusing with the heads and intakes when they come up for sale.61SD tripower and 4 bbl intakes wont fit pass car 61 heads.Tom
Old 03-08-2019, 11:48 AM
Sirrotica's Avatar
The chances of him having a 61 SD intake is slim, but I was speaking about daily driver applications, showroom stuff, is all.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-08-2019, 02:55 PM
Great info. Exactly what I was looking for. Thank you very much, Carmine.
Old 03-08-2019, 04:51 PM
1969GiPper 1969GiPper is offline
Is it possible for a 65 intake to only have one threaded hole in the coolant passageway for the coolant temp sender/sensor on the driver’s side and none on the passenger side (like a 66 manifold)?
Old 03-09-2019, 02:35 AM
Dick Boneske's Avatar
Added info on the '64 Tripower intake manifold. Early '64 manifolds and those manufactured after sometime in February, 1964 have the same part number, 9775088, but the later manifolds have ribs on top of the water passage and on the entire bottom area. I believe these were added to increase the strength of the casting to avoid cracking.
Note that the big cars used the heater hose outlet as shown on the first picture. GTO's used a 45 degree fitting to tilt the heater hose outlet.
The first three pictures are of a '64 manifold cast date A284 (January 28, 1964). The second two pictures are of a later manifold, casting date G154 (July 15, 1964).
ID:	507494   Click image for larger version
ID:	507495   Click image for larger version
ID:	507496   Click image for larger version
ID:	507497   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 03-09-2019, 10:01 AM
Keith Seymore's Avatar
Excellent thread; subscribed.
K
'63 LeMans Convertible
'63 Grand Prix
Old 03-12-2019, 02:49 AM
Yes. In fact, I never noticed that the one Bart posted photos of above had two.
What's up with that guys?
Old 03-24-2019, 05:59 AM
K
Ditto. A very nice thread by b-man. Alot of info there. Thanks for sharing that, Carmine.
Old 04-24-2021, 11:09 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
I noticed that some 65 manifolds have a round boss that sticks up right behind the thermostat housing, and some don't. Is this a way of telling big car tripower from GTOs?
Old 04-25-2021, 10:41 AM
Each year Pontiac Tri-Power intakes are identical for big cars & GTO’s. The boss you speak of is on ‘all 65 & ‘66 Tri-Power intakes.
BONESTOCK GOATS
Old 06-20-2023, 04:19 PM
carbking's Avatar
carbking carbking is offline
B-Man just saw this thread, not sure if I have any pictures of bare intakes, will check, but here is a listing of casting numbers:
https://www.thecarburetorshop.com/Mu...bmanifolds.htm
At one time or another, I have had at least one of all of the Pontiac production tripower intakes.
Jon.
Old 11-22-2024, 04:23 PM
hobbygto65's Avatar
If your 62 has a newer motor it won't fit.
