Old 07-05-2023, 09:20 PM
bober bober is offline
Default TA with 4 spd alt and all other mounting brackets ?
Are These diff than other models? Olds or Pont ?
Old 07-05-2023, 09:59 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
Olds and Pontiac are two completely different engines. None of their brackets will interchange.
I'd think 4 speed and automatic brackets would be the same.
Only exception might possibly be the alternator brackets.
Cars with rear window defogger require a bunch more juice to run that heated grid. The higher Amp alternators had larger cases, requiring larger brackets...
Shut it off
Shut it off
Old 07-05-2023, 10:01 PM
