Industry Stuff new repro's, updates, other info.
Old 07-31-2023, 05:12 PM
1964pontiac 1964pontiac is offline
Default 1965 Bonneville side molding clips
I need 3 clips for the driver side chrome piece that is between the door and rear wheel housing. The holes are 1/4 inches. I've already contacted Restoration Specialties that specializes in clips but they had nothing for my application. Thank you.
ID:	617151   Click image for larger version
Old 08-01-2023, 11:17 AM
GTO.PAUL GTO.PAUL is online now
Default Clips
I have hundreds of GM dealership clips from that era. However there are no part numbers or bin labels to say what the application is. If you have a pic of what is correct I may be able to help you out. Paul
Old 08-01-2023, 01:17 PM
Hi Paul,
Thank you for your response. I purchased the chrome piece from Desert Valley Auto and they sent me one clip. The prong is much bigger than the holes in the body. The prong is metal and is 1/2 inch and the holes in the body are 1/4 inches
ID:	617206   Click image for larger version
Old 08-03-2023, 06:25 PM
Cammer-6 Cammer-6 is offline
also try AUVECO
thay are an OEM supplier
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-03-2023, 07:42 PM
Thanks so much for recommending another supplier!
