Old 08-02-2023, 01:06 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Default Head bolt pattern/spacing
Anyone have a diagram or photo of head bolt the pattern with spacing between the bolts? I’m making a TDC stop and forgot my head gasket…
Thx
costs too much
Old 08-02-2023, 02:34 PM
Dragncar Dragncar is offline
The one I made I drilled two 5/8" holes 6 1/4" apart and it worked fine. Drilled a 5/16" hole and tapped it 3/8 x 16 for the stop bolt.
Old 08-02-2023, 02:43 PM
tc's Avatar
tc tc is offline
I do. I'll upload a pic after work.
Old 08-02-2023, 04:29 PM
tc's Avatar
tc tc is offline
here it is
Old 08-02-2023, 04:33 PM
tc's Avatar
tc tc is offline
closer
Old 08-02-2023, 05:42 PM
Formulas Formulas is offline
About 6.1 ctc this direction..
If your off a touch a rat tail file will make it right
for the stop bolt i welded a 1/2 nut to 1/4 thick band stock with a 1/2 hole in it
also rouned the face of the stop bolt
Old 08-02-2023, 05:46 PM
Schurkey Schurkey is offline
Make the head-bolt holes slotted (at least one of them) so the tool can be used on multiple brands of engines, or shifted side-to-side to avoid piston domes/dishes.
Old 08-02-2023, 07:58 PM
Gach's Avatar
Gach Gach is offline
You can buy them on Amazon $15.00
https://a.co/d/1bC5Zzm
Old 08-03-2023, 08:13 AM
A spare 4-Bolt Main Cap works well.
