SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 08-25-2023, 07:41 AM
GTOLou GTOLou is offline
Default 67-69 Firebird/Camaro 10 bolt, 8.5 rear end. 2000$ - obo. local pickup/upstate SC
Here is the listing I have on FB:
This is a first gen 10-bolt GM rear end. Perch's are deep/for multi-leaf springs. 42 7/16" wide between perches. Fits 67-69 Camaro's and Firebirds. I think* some Nova's too. It's new rebuilt/never broken in or used, built by online or Jim and JD racing. Here is the spec:
specs-
-10 bolt 8.5 housing mutileaf perch set-up media blasted, cleaned in and out, primed and painted chassis black.
- Spring perch center to center is 42 7/16" Stock firebird Nova Camaro
-NEW EATON 30 SPLINE POSI UNIT. ****UPGRADE**** normal is 28 spline
-NEW 3.73 YUKON BRAND STREET/STRIP PERFORMANCE GEAR SET.
-NEW YUKON BRAND HEAVY DUTY 30 SPLINE STREET/STRIP ALLOY AXLES DUAL DRILLFOR 1/2 OR STOCK PRESS IN STUDS. ****UPGRADE**** normal is 28 spline
-ALL NEW TIMKIN BEARINGS INCLUDING AXLE BEARING AND SEALS.
-BACKLASH SET AT .007 FOR PERFORMCE APPLICATION
-BACKING PLATES INCLUDED
ID:	618755   Click image for larger version
ID:	618756   Click image for larger version
ID:	618757   Click image for larger version
ID:	618758   Click image for larger version
Old 09-02-2023, 11:26 AM
Bump 1500$
Old 09-03-2023, 10:27 PM
grivera's Avatar
grivera grivera is offline
Nice rear - what is width drum to drum?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 09-04-2023, 12:47 PM
BDHABT's Avatar
BDHABT BDHABT is offline
Looks like a nice unit.
Don`t see many Pontiac guys from Anderson SC.
We`ll be moving to that area in a few years.
GLWS.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 09-04-2023, 04:31 PM
Looks like outer width is right at 60" and inner width (inside of backing plate) is 53.5.
Yeah - its a good rear end. Never used since being built and is about as strong as a coveted 12-bolt first gen Camaro/FB rear end.
Old 09-09-2023, 08:08 AM
Forgot to update this:
1500$. Local pickup. Ready for install - forged axles/posi/new brakes/drums, etc. Never installed or broken in. Built by a pro!
Old 09-27-2023, 08:37 PM
This is sold.
