I need a rear lighting harness connector to the ribbon wire for a 64 goat, damaged mine, can,t get in touch with m/h electric to buy one, anyone have one.
Can you post a picture of it, have some 64 -65 stuff.
But I'm in Canada so might take a while to get there.
64 Lemans hardtop 4spd, buckets |
Here are pictures of the rear lighting harness from my 64 convertible. not for sale but may help you find one.
I NEED the black connector on the end of the 1964 GTO rear wiring harness.
i NEED THE BLACK CONNECTOR TO THAT HARNESS
Isn't that part of ribbon harness?
The Following User Says Thank You to Lemans64 For This Useful Post: | ||
iTS THE BLACK CONNECTOR AT THE END OF THE REAR WIRING HARNESS, NOT ON THE RIBBON, IT CONNECTS THE REAR HARNESS TO THE ROBBON WIRE
Photos of 64 Le mans convertible body ribbon harness. Black connector is where rear tail light harness plugs into. Are you looking for a male or female connector?
64 very hard to find and not reproduced to my knowledge. .65 harnesses are reversed from 64. I beleive 65 are reproduced. |
Not sure which connector you are looking for. Sorry for any confusion, But is the connector by the fuse box or by the rear seat? The dirty connector is on taillight harness at or under rear seat area. Clean connector is at fuse box location. Both of these plug into black connector on ribbon harness.
64 Lemans hardtop 4spd, buckets Last edited by Lemans64; 10-05-2023 at 08:49 PM. |
Rear lighting harness wires terminate at this black connector that plugs into the ribbon wire has a hook on each side that connects to the ribbon wire
![]() Quote:
so who have you contacted that makes harnesses?
what was your failure in contacting M&H?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Your connector is not like the post 8 picture? That connector is part of the ribbon harness I believe.
