Fuel pump
I need a new fuel pump. I have a mildly modified 389 tri power with a 4 speed and 3.42 rear. What would be the best mechanical fuel pump for this application? Is any replacement pump fine?
The best mechanical fuel pump (in my opinion) would be a 6 valve Chevrolet lower section
added to a Pontiac upper lever/housing with the mods done by Ken Crocie. If I remember correctly, Ken did the mod on several Pontiac engines over the years. Then you have a great flowing street fuel pump. Tom V.
I have used the Carter street pump for years on my421s and 455s.Tom
X2 Mike
Thanks guys. Looks like I will get the Carter street pump.
25+ years ago i found i was leaving a lot of power at top end on the table using a mech. fuel pump for my 1966 Tripower GTO.
Also had problems with fuel percolating at engine shut-off. Since then i´m using a Carter P4070 electric pump as a replacement for the mech. Not looking back..... |
Carter HP m6907 mech pump is perfect / my 461 with 66 trips 500 hp has been flawless now for years 3/8 pick-up & line .
Just remember, about 6 psi is all the Rochester carbs can tolerate. that is plenty to get adequate flow through three needle/seats.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
I used an AC 40373 pump on my tripower engine. It works just fine. I initially tried one that was for a late 70's 400 and it overpowered the needle and seat on the carbs at idle and when you'd shut the engine off it would leak down. I ran a regulator for a while and cranked it down to 6 psi. It did better. However, I didn't want to run a regulator. The AC 40373 Pump took care of the problem. The carbs just won't tolerate much over 6 psi of pressure.
I was concerned about too much pressure, that's why I asked what others used. Thanks everyone for your input. Going to install the new Carter street pump tonight.
I posted quite awhile ago that a new Airtex mechanical pump we purchased was pushing 10 PSI, and it turned the carbs into bubbling fountains. We hid a 1-4 PSI Holley 12-804 regulator just above the pump and solved the issue.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
Bringing back an old(ish) thread because my 22 year old Carter M6907 pump finally died. I called Carter for a rebuild kit and they sent me to Then and Now Automotive in Weymouth, MA. They manufacture rebuild kits here in America and have a kit listed online (CK6907) but I called in to ask a couple of questions. I spoke to Tom, he was very knowledgeable and asked me a few questions about my pump (most important-is it USA or China made and what is the casting number.) It turns out they can send you different springs for the diaphragm to adjust the fuel pressure. Stock Carter M907 is a minimum of 6 1/2 psi (he figured even more.) He sent me springs to go higher (not what I wanted for my tri power) or lower, closer to 4 or 5 psi, which is what I wanted to achieve with a new regulator. I'll be doing the rebuild over the next couple of days and will report back with the results.
You can look up Then and Now Automotive on youtube to see the rebuild process for a Carter fuel pump. No reason to not DIY. |
The Following User Says Thank You to MrArt2u For This Useful Post: | ||
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Is there a reasonable source for the spring that regulates fuel pressure in these pumps? During the past five years, I've had more than a dozen Tri-Power owners with flooding issues due to too much pressure. Several claimed they bought the low pressure pump from Ames Performance, and saw more than 8 psi at the carbs.
I don't believe there is a reliable source of Pontiac fuel pumps that deliver less than 6 psi.
I just looked the Carter M6907 pump on Summit's website and it says it puts out 6psi. May not be right but that's what it says.
Have used the 6907 for years on multiple tripowers trouble free , standard needle & seat , not the flapper disc style , never had any issues .
Is there a source for rebuild kits for the ‘65 and earlier pumps? I’ve got six NORS pumps that could be rebuilt if I had the parts. I would get them dichromated for NOS appearance and ethanol-proof with new diaphragm.
Dick - try "Then and Now" in the Boston area.
Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
