Old 11-09-2023, 10:22 AM
56GMC's Avatar
56GMC 56GMC is online now
Default New Rear Springs & Gears for '62 Cat
Finally got around to cleaning up the rear suspension & changing the gears from 2.69 to 3.42 posi. Replaced the control arm bushings & boxed the lowers to accommodate the sway bar. PO had 1”spacers on the coil spring pads so fitted new parts from Eaton, MC 1505+1. These are 1" longer than stock & the photo shows the new stance.
ID:	623064   Click image for larger version
ID:	623065   Click image for larger version
Old 11-09-2023, 11:08 AM
pfilean's Avatar
pfilean pfilean is offline
What sway bar do you have? Doesn't look factory. Bolt in? And did it require boxing the arms with the mounting bolts?
Old 11-09-2023, 07:47 PM
694.1 694.1 is offline
Looks simply awesome. Pretty big bar though, not sure you can swing enough rubber to really utilize the bar?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-09-2023, 09:08 PM
Shiny Shiny is offline
Way to go on the changes. The lower ratio should be fun for you.
The car itself is really striking! What a beautiful car!
Old 11-11-2023, 08:52 AM
56GMC's Avatar
Used a 68-72 A-body bar from UMI & drilled my own holes in the control arms. Welded in tubes surrounding the bolts then added flat stock to make the arms very robust. More details on my 2020 thread. Have to start taking more before & after photos!
Old 11-11-2023, 11:25 AM
pfilean's Avatar
Thank you. I wondered if you had put pipe sleeves in the arms to take up bolt compression. Good solution.
