OHC-6 TECH Over Head Cam projects, questions and advice.
Old 11-11-2023, 07:25 PM
Cammer-6 Cammer-6 is offline
Default whats your car weigh?
I was discussing this with a son. I told him I bet our 67 Tempest Sprint weighs less than our 4WD 2 dr S10 Blazer.
Im guessing the 67 weighs about #3400.
Sprint sport coupe factory AC,PS,PDB,
Trans is a 200-4R
Please list all the major options with your weight
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 11-11-2023, 08:54 PM
Jeff Hamlin's Avatar
Thumbs up AMA SHEET
Shows my '66 with options shown as 3644#
I've added several more options over the years and run on larger tires.
But would say it's still under 3800#
Old 11-11-2023, 10:58 PM
694.1 694.1 is offline
My 67 Sprint Bird was 34ish. That was with fluids.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-11-2023, 11:33 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
This was before the turbo. So OHC with Sprint intake/exhaust manifolds, 2004r, 8.5" rear axle and about a 3/4+ tank of gas iirc. On Drag Week I rolled across the scales at about 3,400lbs flat sitting in the car with the turbo system, 4L60e, 9" nearly full tank and in the car.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 11-12-2023, 12:10 AM
WQ59B WQ59B is offline
Power discs on a '69 Firebird add 28 lbs [~ AMA specs]
Old 11-12-2023, 10:20 AM
using Jeffs chart(but mines a 67 not 66)
mine comes out pretty close to what I guessed at 3440#
Now seeing that post about the brakes I need to add another 28#
so its 3468#
