Old 11-13-2023, 12:37 PM
Keith Seymore's Avatar
Default '63 389 Tripower upper rad hose
Do any of you all have a preference or recommendation relative to an upper radiator hose for the Grand Prix?
I see the Ames catalog shows two, either of which would fit based on the description.
When I installed the tripower I reused the 4 bbl hose that was on there. The fit is OK but wondering if it could be better.
Thanks in advance -
K
'63 LeMans Convertible
'63 Grand Prix
Old 11-13-2023, 12:45 PM
tom s tom s is offline
Keith,the one included 64 tripower?The thermo housing in 64 was pointed the other direction?Tom
Old 11-13-2023, 02:18 PM
Not sure.
I used what I had on hand -
This hose has developed a sort of cut on the underside:
Name:	GP Tripower 2.jpg
ID:	623255   Click image for larger version
Name:	GP Tripower 1.jpg
ID:	623256   Click image for larger version
Name:	GP Tripower installed.jpg
ID:	623257   Click image for larger version
'63 Grand Prix
Old 11-15-2023, 12:09 PM
pfilean's Avatar
pfilean pfilean is offline
Original part number for 61-63 P/8 was 538568 for manifold outlet. 538821 for hose. Which should be the PP249 number. Back in 1961 there was a Craftsman News item cautioning to cut 1 inch from the radiator end to prevent wearing a cut where the hose rubbed the left air silencer snout. But I presume the 538821 number had taken that into consideration and if you don't use the big air cleaner anyway it shouldn't matter.
Old 11-15-2023, 12:42 PM
Thank you;
I looked at it again last night and I think I may have enough length to cut the diseased portion off and put the clamp up higher.
Thanks again -
K
'63 Grand Prix
