I'll post pix tomorrow, I can't right now, the car's at my shop and I'm not there right now.
GREG'S GOATS: 1970 GTO Judge RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970. 1968 GTO 461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's. 1966 GTO Ragtop 4-Speed, AM/FM, Original driveline. |
You were smart to bend it before you put in on the car. Glad it worked out for you.
Greg Reid Palmetto, Georgia |
It's pretty much the same as Greg's, and I had the same problem with the filler neck. I had to bend it to make it fit the opening in the bumper. Wasn't too bad. If I had it to do all over again I would have gone to Advance. Frankly, I never thought of that at the time.
It worked out pretty well...
Bumping an ancient thread! I am in need of a new gas tank for my '68 Lemans. The original tank was fine, but I removed it when I was planning to go with an in-tank pump. I got the new tank and gave the old one away. Now I have changed my mind on the in-tank pump and need an original type tank.
My question - does anyone manufacture a correct '68 tank? I know I can modify a '69 tank and I'm ok with that; I'd just prefer something ready to bolt in if it's available. Thanks, Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
the 69 style works fine & Spectra made a nice looking & fitting tank. you just have to bend the filler neck up a bit to have it sit where its supposed to in a 68, but its really no big deal. The one I bought was made in the Spectra Canada plant. I was very happy with it. I assume they still make them there?
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
The Following User Says Thank You to 68ragtop For This Useful Post: | ||
Here's a later thread to show a simpler way to get the '69 neck aligned with the '68 bumper opening. Very easy but you have to keep a close watch on the solder joint. It could be touched up easily with a butane torch or big watt soldering iron if necessary.
https://forums.maxperformanceinc.com...ht=Filler+neck
The Following User Says Thank You to Greg Reid For This Useful Post: | ||
Ames sells the correct tank with neck for 68 . I just put one in mine early this year . They have a stainless version too . Part # L205R
The Following 2 Users Say Thank You to locomotivebreath For This Useful Post: | ||
![]() Quote:
Scott
It's about time someone did that.
Got it installed this weekend. The neck was surprisingly easy to bend.
The Following User Says Thank You to bulletpruf For This Useful Post: | ||
Good deal. Make sure that there's no spider web cracks in the solder.
