OHC-6 TECH Over Head Cam projects, questions and advice.
Old 12-15-2023, 02:04 AM
justincampbell's Avatar
justincampbell justincampbell is offline
Default Sprint vs 1bbl parts differences?
Is the head or the crank/rods different between a Sprint motor and a 1bbl motor in '66?
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 12-15-2023, 06:55 AM
Jeff Hamlin's Avatar
Short Blocks are basically the same.
Cam, Head, Manifolds, Carb.
Old 12-15-2023, 11:01 AM
Cammer-6 Cammer-6 is offline
they did advertised that bearings were upgraded in the 4 bbl
but as Jeff says otherwise identical(also sans balancer)
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-15-2023, 05:24 PM
Is a Sprint head or block (ZD) worth much if they need gone thru the machine shop (and possibly one sleeve)?
The mice took up temporary residence in a couple of the cylinders at some point.
Easyrider
Old 12-15-2023, 06:11 PM
Unless its for a number match scenario a block that needs sleeved is worthless IMHO.
Old 12-15-2023, 06:36 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Pretty much all modern bearing and ring offerings are superior to 1960's OE parts, so isn't a real consideration when comparing the 1bbl to 4bbl today. Pistons, crank, rods and block are the same.
Outside the obvious intake/exhaust manifolds, the cylinder heads and valve lengths are different for compression, valve springs are different for the two cams. Then the harmonic balancers are different, with a higher weight on the 4bbls.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
The Following User Says Thank You to TheSilverBuick For This Useful Post:
