Old 01-26-2024, 09:37 AM
Gary H's Avatar
Gary H Gary H is offline
Default 400 small register crank strength
Getting ready to build a 78' 400 for a customer and it has the lighter, thin counterweight, small crank register crank in it. Has anyone had any issues with these cranks in a performance application? The engine will have out of the box KRE D port heads and a hyd. flat tappet cam, probably be around 390-400 Hp range. I have other earlier N cranks but would like to stick with this crank since it's std/std., if it's strong enough.
Old 01-26-2024, 10:10 AM
I would only have a start for concern once the 475 to 500 hp level was being reached.
The core of the crank where it counts in terms of strength is still the same, as in from a main or rod journal to the crank cheek.
Plus with a 3.750” stroke the rod fillets are seeing 12.5% less G force then if the motor was a 455.
Old 01-26-2024, 10:44 AM
Consider most Chevy motors have a small register too.
Old 01-26-2024, 11:52 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Great option... A lot of Super Stock's run these.
Go fast, see Elvis!
Old 01-26-2024, 12:44 PM
Gary H's Avatar
Thanks Paul! I thought I had heard that a while back too. I'm going to use it.
The Following User Says Thank You to Gary H For This Useful Post:
Old 01-26-2024, 12:46 PM
Gary H's Avatar
Wasn't worried about the small register per se. I was only mentioning to help identify which crank I was referring to that had the narrow counterweights. I've decided to use it.
Old 01-26-2024, 01:11 PM
Gotcha!
Like Paul said some of the "Stocker/SS folks" run them.
Stick or auto?
Old 01-26-2024, 02:09 PM
PAUL K's Avatar
Gotcha!
Stick or auto?
Hi Skip, I know of a few auto trans cars. It's a nice way to remove several pounds of rotating weight. Every so often I come across a light weight casting with a large flywheel register.... Those are the hot set up.
Go fast, see Elvis!
Old 01-26-2024, 06:14 PM
phil400's Avatar
phil400 phil400 is offline
What the part number on the crank? Just curious, I tore down two later 400s not too long ago and both crank had a 350 part number on it
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs,mine since ‘99.
79 Parisienne just got it
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
Old 01-26-2024, 07:50 PM
mgarblik mgarblik is offline
I know Bill Rink, (RIP) used the small register, light cranks in his stock and SS 74 GTO. That was a 350 inch engine however. He ran it hard and at high RPM's. 10.60's. Not aware of him ever breaking one.
