Old 08-05-2023, 09:47 AM
Joe37 Joe37 is offline
Its ready to go in the chassis,
ID:	617448   Click image for larger version
ID:	617449   Click image for larger version
ID:	617450   Click image for larger version
ID:	617451   Click image for larger version
  #102
Old 08-05-2023, 09:51 AM
More,
ID:	617453   Click image for larger version
ID:	617454   Click image for larger version
ID:	617455   Click image for larger version
ID:	617456   Click image for larger version
  #103
Old 08-07-2023, 08:57 AM
TAKerry TAKerry is offline
Beautiful!
  #104
Old 08-09-2023, 09:20 PM
78Macho 78Macho is offline
Default Update on engine and tranny...
Well, there you have it folks! I took the tranny mount over tonight. It's a wrap, the engine and tranny are ready to go back into the car! Easier said than done, maybe? Plans are being made to haul it back to my house and get it in the car. Believe the most positive part of the process will be the fact that the radiator/core support is not mounted and the unit will slide in more than it will need to be raised and then lowered into place.
Keep you posted.
  #105
Old 08-27-2023, 08:06 PM
Default Christmas in August
Well, here you go! A million miles ahead of where it has been slumbering for many years. While I still have a chunk ahead of me before it actually fires up and the car is running again, I am stoked to be right here!
A huge thanks to Joe Hand for his expertise in getting this engine and transmission rebuilt, running and ready to go back into the car. His brother Tom came out this afternoon to lend a hand.
I believe it is safe to say that is has been at least 35 years since this motor has been in the car!
Name:	Engine after Aug 2023.jpg
ID:	618971   Click image for larger version
Name:	Engine after 2 Aug 2023.jpg
ID:	618972   Click image for larger version
Name:	Engine after 3 Aug 2023.jpg
  #106
Old 08-27-2023, 08:53 PM
Very nice!
  #107
Old 08-29-2023, 10:46 AM
I'll pay for the gas for you to give me a hand getting to that point!
  #108
Old 10-14-2023, 08:18 PM
you're making some great progress!! Some observations you may want to look into. the heat shield doesn't look correct on the exhaust manifold. i believe the one on yours is for ealier setups. Also, the front pulleys look like they would be for an A/C car. non A/C got a larger water pump pulley and smaller crank pulley.
my original plan for my 79 TA was to make a w72 copy. that lasted for a year before i went a whole different direction with the 428... lol
2007 Grand Prix GXP 5.3L
  #109
Old 10-14-2023, 09:44 PM
Pretty sure you are right about the heat shield. The pulleys are for a A/C car, went that way for the extra cooling byway of higher rpm on the water pump. Due to the extra cubic inches, any help with cooling is a plus.
  #110
Old 10-16-2023, 09:29 PM
Poncho Dave Poncho Dave is offline
Looks great!
  #111
Old 11-05-2023, 05:56 PM
Default November update
Anniversary of purchasing the car was last month, 4 years ago and counting.
First, thanks for your input on my restoration. Given the fact the car wasn't complete, as it was 100% advertised as, I wouldn't be struggling getting it put back together correctly. So far I now have an incorrect exhaust heat shield, air cleaner breather tube and starter support bracket for sale!
1. Correct heat shield sourced and installed.
2. Gas tank straps refinished, I had painted them black, they were originally a galvanized, natural finish.
3. Attempting to paint the core support for the third time. I had it blasted and the media they used was too harsh.
4. Purchased a catalytic converter mounting bracket (thanks Jason), refinished it and ready to install.
5. Purchased an original, low mile correct catalytic converter (thanks Jeff).
6. Purchased an NOS header pipe. Picking it up on the trip to MCACN later this month.
7. Purchased a correctly dated, Norwood, space saver spare tire.
Currently looking for a reverse lockout set up, another item missing!
Punch list made for getting the car back on the ground for the first time in several years, including getting brake fluid in the new system.
Albie McHenry, the original owner, said he ran across the original salesman that helped him order the car at Coopers. Unfortunately, the conversation didn't go far in reference to the Trans Am. But, at least I have a name for the history book. Thinking about getting a business card made up to put in the owners manual packet!
Name:	1979 Cat and bracket.jpg
ID:	622848   Click image for larger version
Name:	1979 space saver spare date code.jpg
The Following User Says Thank You to 78Macho For This Useful Post:
  #112
Old 11-05-2023, 06:30 PM
Default one more item
I forgot to post this. I found a guy on ebay that had a bunch of blank, original Pontiac "New Vehicle Inspection Procedure" forms! The form is two part, white outer copy is for the new car owner and the yellow is for the dealer file.
Think I am getting close to having a complete owners manual packet for the car!
Name:	1979 Pontiac procedure form.jpg
  #113
Old 03-02-2024, 09:33 PM
Default Slow moving
Guessing the reverse lock-out linkage search was in top three items that were not to be found. Came down to asking a couple of parts sources to go their sources! One afternoon, I had two to choose from! One was heavily coated with rustproof undercoating and I bought it. Price was fair for how rare an item it is.
I have the exhaust a third of the way done now. Haven't decided how I will finish up, aftermarket or I know of an NOS system ($$$).
Just got the rubber mounts for the radiator.
Stay warm and safe, spring is around the corner!
Name:	Cat march 23.jpg
ID:	629713   Click image for larger version
Name:	linkage mar 24.jpg
  #114
Old 03-04-2024, 08:53 AM
Beautiful.
